exhaust routing
Just finished up C-channeling rear suspension and scratching my head as to where to route the exhaust without interferring with ground clearance. I'm bagged on 4 corners w/3" drop spindles and of course c-sectioned rear frame and raised the rear axle up 2" from rear control arms. This, in lowered stance form is about 4" from the ground. I would like all exhaust above the lower frame rails. I thought about running it through the frame (cutting and welding gusets in) under the cab and running it along the outside of the frame rails to rear of truck. Any suggestions?
70 chev c-10, bagged, shaved, and slammed 99 Screamin Eagle 103ci Road King HD 68 SS Chevelle BB 02 Denial (Denali) IF IT HAS TITS OR WHEELS YOU'RE GOING TO HAVE PROBLEMS! |
F.A.S.T. president
![]() Join Date: Sep 2003
I have the same set up minus the bags and here is what I did and nothing hangs below the frame. I have the mufflers on but no picture of it. I also havent decided on the arrangement of the tail pipes.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 10-05-2007 at 07:12 AM. |
