Speedo Questions
Surely somebody has seen this. I can be going along just fine (even though my speedo is 10 mph off) and all of a sudden my speedo will fluctuate up and down from 50 to 90 quickly. When this happens, I can hear a very faint sound. It sounds kinda like a buzz, but it might be the cable vibrating or something. Anyway, then it stops and settles back to being 10 mph off. I figure the reason it's off is due to gear and tire sizes. This leads to my next question. Does anyone know where to get new gears for the speedo? Preferrably the driven gear.
Thanks in advance.
Why do we drive on a parkway and park on a driveway? ![]() |
i have the same exact problem.... ive just let it go for a while....worse problems to take of.....like a cracked frame....
-Chops- |
If I can get the fluctuation out of it, I can deal with the 10mph off. Glad someone else had this problem. Now to get someone to point us in the right direction. Anyone???
Mine also sticks at 60 mph then eventually will jump up to the proper speed once i get going around 70 mph or so.
-Chops- |
Senior Moment
![]() Join Date: Mar 2002
Lube the cable
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Could be a cable binding then letting go whipping the needle up or possibly the head itself. Inside the head a magnet spins inside a cup which is balanced with a spring, if the mag touches the cup it will whip the needle up also.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
![]() Join Date: Sep 2001
I purchased new gears, housing, and clip from these guys. This will get your 10 mph correction.
http://www.transmissioncenter.net/sp...n_______va.htm |
