Old 05-14-2005, 08:55 AM   #1
meathead95
computer illiterate
meathead95's Avatar
blazer tank ?
I put one of the replacement steel blazer tank kits in my blazer. in which I am sure it is a 21 gallon tank. but for some reason everytime I fill it up it only takes 12 gallons? I used the sending unit that came with the tank. I am wondering if the sending unit isnt deep enough, does anyone else have this problem?
thanks
keith
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 05-14-2005, 10:29 AM   #2
kaycee
kaycee's Avatar
My tank measured approxamately 27"x27" x12" deep mine was for a pick-up,The sending unit is for the gas gauge are you questioning the reading of your gauge?
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 05-14-2005, 03:34 PM   #3
meathead95
computer illiterate
meathead95's Avatar
yes the same tank you put in a pickup is the one i have in my blazer. but when it says it is empty it will only hold 12 gallons when you fill it up. and i know the tank holds more than that so im thinking they gave me the wrong sending unit with it and it doesnt go deep enough in the tank. i was just checking to see if anyone else with the steel blazer tank kit has this problem
72 2wd blazer
72 swb 4x4
Old 05-14-2005, 04:13 PM   #4
RED72blazer
urban fourwheelin
RED72blazer's Avatar
I just put s new tank in mine and have had some trouble too. Are you saying that you can't fill the tank all the way full? Cause i have the same problem I'll get about 12-15 gallons in it and the pump will shut off. then if I pulll the nozzle out a bit it wil fill the rest of the way. not sure this helps just my experience.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 05-15-2005, 02:06 PM   #5
meathead95
computer illiterate
meathead95's Avatar
no i think im getting it full i just think the guage only reads the top half of the tank.
72 2wd blazer
72 swb 4x4
Old 05-15-2005, 03:01 PM   #6
longnlow72
longnlow72's Avatar
my blazer tank in my truck when i fill it up the gas gauge only goes to 3/4 full so at empty it only takes that much, does ur gauge go all the way to full?
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done...
longnlow72 is offline   Reply With Quote
Old 05-16-2005, 08:39 AM   #7
meathead95
computer illiterate
meathead95's Avatar
i dont have that problem when i fill mine up it reads full but i can run the needle all the way to empty and it only takes 12 gallons to fill it.
72 2wd blazer
72 swb 4x4
Old 05-16-2005, 09:18 AM   #8
Mudder
Mudder's Avatar
Are you sure the sending unit is the right ohms? I was using a newer sending unit with my old guage and it was stupid like that. Sometimes it would go way past full. Other times it would just go to half a tank.
Mudder is offline   Reply With Quote
