Old 05-14-2005, 10:51 AM   #1
Paul72
Paul72's Avatar
FS - Poly side tanks
I have left and right side tanks (approx 15-16 gal each). The left tank has a small crack on the top of the tank. Tanks come with sending units.
$30 each or $50 for the pair (plus shipping).
Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 05-14-2005, 01:42 PM   #2
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Paul,
How do these tanks mount to the truck? Do they require cutting holes in the box sides for the filler neck? How bad is the crack?
Thanks in advance,
Wes
badpeanut is offline   Reply With Quote
Old 05-14-2005, 03:11 PM   #3
qksilver
put me inline please, pm me
Thanks,
Steve
qksilver is offline   Reply With Quote
Old 05-15-2005, 07:03 PM   #4
Paul72
Paul72's Avatar
Here are some more pics. The tanks were mounted to the bottom of the bed cross-sills with two aluminum straps (similar to gas tank straps) and thru-bolted through the cross sill. There is a hole in the bed side along with a notch in the trim. I thought about re-routing the neck to the front stake pocket, then I decided not to use them. The crack is on the top surface and, ironically, is on the tank that had fuel in it.
Paul
Old 05-15-2005, 10:08 PM   #5
badpeanut
badpeanut's Avatar
I will take the passenger's side (the non-cracked one). Sending PM...
Old 05-15-2005, 10:24 PM   #6
Paul72
Paul72's Avatar
Pass side sold.
Driver's side $25 to your door.
Paul
