Seņor Member
FS: 2" rear lowering block kit for coil rears
Pulled from my truck after 5+ years of reliable service. I'm offering the pair of 2" blocks, 2 u-bolts, lock washers, and nuts. They'll need some cleanup if you want them to look pretty... and one of the u-bolts will need some thread chasing (threads are dinged into one another a bit on the end).
These things are $70 new at CPP. I'll take $25 + $7.70 USPS flat rate Priority shipping. PM if interested. (reference pic below... mine are grimy and grungy)
You have PM.
Got Big Block?
if Scoti doesn't take them I will. thanks.
"Experience is what you get when you didn't get what you wanted." |
Active Member
![]() Join Date: Mar 2005
Next in line
67 short step ![]() 71 Custom ![]() |
Me too, if it gets to me.
72 C-10 |
