05-14-2005, 01:12 PM | #1 |
Still drivin' a Rat Rod
engine ID.
Just dragged the 81 home,and it has what appears to be a tall deck BB in it.The guy I bought it from says it's a 427,and then I hear it's a 366 so here are the numbers from the front of the block,if that will tell me anything.
Can someone decipher this or tell me how to ID the motor? these are right above the timing cover in the center of the block T1017AXX Any information is appreciated,thanks
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
05-14-2005, 02:22 PM | #2 |
Suffix codes
I looked at this web site and they have a large selection of stampings . It is a truck motor that was assembled on October 17 . What is the casting date on the block ? That might help also . I dont see a stamping AXX but there is a 4XX. Here is the link in case it is actually something other than AXX .
http://www.chevy-camaro.com/chevy-ca...es.asp?group=1 Frank |
05-14-2005, 06:31 PM | #3 |
4XX 1994 454 310 Marine L-19 4 bolt In/Out
I didn't look ath the code,a buddy did,but it prolly is the one above,which makes me very happy I was told it was a 366,454 is much better. Thanks. <edit> I went and looked,and it is a 454.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website Last edited by Brainchild; 05-14-2005 at 06:37 PM. |
05-14-2005, 09:34 PM | #4 |
That is definitely a good outcome . By the way , that website has just about every suffix listed . Just click on the dropdown at the top and select the correct range . Frank
05-14-2005, 10:47 PM | #5 |
Yeah I bookmarked it for later too.Thanks for the link.Good stuff
