Old 05-14-2005, 04:23 PM   #1
6772king
6772king's Avatar
WTB 373 gears ,,,dana 60
any one got a set ???? I need them the front but I think the rear ones are the same??? let me know what you got if any thanks Sean
67 chevy short step 2wd 427
71 chevy short fleet 4x4 396
72 gmc jimmy 2wd 377
71 chevy blazer 4x4 454
69 chevy longhorn 5.9l cummins
72 chevy 400 2wd custom camper
67 chevy lwb 4x4 454-in pieces
67 chevy panel soon 4x4-400
67 gmc dump 4x4 1 ton-305 WTF!!
72 chevy 3/4 ton 4x4 burb 350
70 chevy panel 2wd 302 5 speed tko
"THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!!
6772king is offline   Reply With Quote
Old 05-17-2005, 04:12 PM   #2
stan79chevy
stan79chevy's Avatar
how hard is it to get them out?
in the woods behind my dads place there is a ford truck bed that was turned into a trailer back in the old days. it has a dana 60 rear end in it and the gear ratio is 3.73. i popped it open last summer to see if it may be 4.56 gears that i could use in my truck. i dont know if theres a difference in front to rear or ford and chevy? let me know how to get it out and how much and i could probably do it this weekend.
stan
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 05-17-2005, 05:13 PM   #3
6772king
6772king's Avatar
are you still looking for 456s???? I have a set that we could trade if you wanted... as far as price,,, whatever they are worth to ya and your time taking them out,,,dont know what a used set for a 60 would be worth,,, I sold a set for a 44 on here last year for 30 bucks,,, but like i said whatever you want for them,,,thanks ,,,,Sean
Old 05-18-2005, 03:09 PM   #4
stan79chevy
i allready got 4.56s
to bad your so far away id let you take them out yourself and have em. if i have time sunday ill head over there and get them out of there. how complicated is it? what do you have for a trade?
stan
4.56 gears rock
LWB pimer black
4.3/4L60E/233
Old 05-18-2005, 09:57 PM   #5
6772king
6772king's Avatar
dont have much for your year truck,,, is there anything you need,,,my cousin has a bunch of 73-80s,,, as far as getting them out I dont think it is to bad,,,
1st,,, take the pinion nut off and pull the pinion yoke off
2nd ,,, pull both axels out
3rd,,, take the cover off and remove the four carrier bolts and 2 caps,,the just pull the carrier and ring gear out then push the pinion out though the same way,,,
if you can it would be great,,, let me know how you make out,,,thanks alot Sean
