05-14-2005, 10:47 PM | #1 |
Dana 60 question
I have a 1987 chevy dana 60 front end w/ 4.10 gears and open. I found a guy who has a trac loc and 4.10 gears out of a chevy rear end. I know the rear trac loc is 30 spline and my front is 35 spline. Does anyone know if I can use this in my front with different spider gears? And will the spider gears out of my open carrier work in the trac loc? Thank's in advance Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) |
05-15-2005, 03:04 AM | #2 |
I want to help you...
I know power locks will work in the front with 35 splines if you use the dana 70 rebuild cones and stuff. Not to sure of the trac locks..... But ttt for ya
Support The Board |
05-15-2005, 11:06 PM | #3 |
That sure sounds like a post I asked a bit ago..might help you out also..here's the link since search is down.
http://67-72chevytrucks.com/vboard/s....php3?t=146223 I'm still not all that clear on what fits though.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
05-21-2005, 11:30 PM | #4 |
Hey everyone, I just thought I'd share what I learned on this subject. In my case with the Trac Loc I called reider racing and one of their tech guys had the answer. With the trac loc I can order a rebuild kit with proper spider gears to make it a 35 spline for $145 (which is what I'm doing) or you can get just the spiders for $60. Thank's for the input Jason
