Old 05-15-2005, 06:51 AM   #1
Alan Potter
Question Disc brake swap on '67 half ton
I'm sure this has been asked before, but I'd like to change from drum to disc brakes on the front of my '67 1/2 ton. What other year spindles would work as a direct replacement. I'd rather buy used instead of spending the big bucks for a kit. I'd also like to stay with the 6 lug set-up instead of changing to 5 lug, but I'm not aware if chevrolet used a 6 lug disc from the factory. AP
Alan Potter is offline   Reply With Quote
Old 05-15-2005, 12:41 PM   #2
cadiac
I'm not an expert on this but I think you'll have to go 5 lug. I did a 70 and changed the whole suspension/The hard way! (used 71-72 parts) I found out later it's easier to drop the whole crosmember. The crosmember from a truck all the way to 1987 will bolt right in. Calipers and hoses are more plentifull for those (newer) years. I'm sure guys with more knowledge will respond. Seems I saw the 5 lug-6 lug question come up before? Maybe someone makes a 6 lug rotor??
cadiac is offline   Reply With Quote
Old 05-15-2005, 12:53 PM   #3
longhorn71
longhorn71's Avatar
you can get afrter market 6 lug rotors but there was no factory 6 lug rotors
longhorn71 is offline   Reply With Quote
Old 05-17-2005, 09:00 PM   #4
Alan Potter
Thanks for the information. I appreciate it Alan
