05-15-2005, 10:07 AM | #1 |
Aftermarket doors
Has anyone used one of the aftermarket doors? Any problems with fit or quality? I bought a SOCAL burb and had shipped. The transporter ruined the door when He was backing it off of the truck . I've been looking for a used one, but am considering a new one. Any suggestions.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 12-12-2005 at 12:46 PM. |
05-15-2005, 11:36 AM | #2 |
Never heard of aftermarket doors for a burb, where did you see them?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
05-15-2005, 02:12 PM | #3 |
Doors
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-15-2005, 02:35 PM | #4 |
Active Member
Chevt duty and GMC Pauls also sell them
http://www.gmcpauls.com/Body&Bumpers.htm http://www.chevyduty.com/frame-store.html
67 short step 71 Custom |
05-15-2005, 07:19 PM | #5 |
I have seen the shells, I assumed (a$$ out of you and me) he was talking about complete doors. I could use 3 myself. Shells wouldn't help me much cause the rest of mine is rusty also.
05-15-2005, 08:49 PM | #6 |
Shells are the complete doors sheet metal wise
05-16-2005, 03:46 AM | #7 |
Yeah, shells, not door skins. I would most definitely source used doors. With all the burb bodies left untouched in wrecking yards and also parted out burbs on this board alone, I would avoid the thin sheet metal of replacement doors. Unless someone makes burb doors with the same thickness metal that orig doors have. Remember, pickup bodies get picked clean long before burb bodies, all things being equal.
One note. If a used burb door has no penetrating rust on its outer skin, then it will likely only have bad rust down at the bottom of the inside where some folks cut holes for speakers. Replacement patch panels are available for this inside door metal below the door panel (vinyl/metal etc.). Having to cut and paste this area wouldn't show outside the truck and can be covered by the ubiquituos carpet covers for the lower inside door metal.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
05-16-2005, 12:07 PM | #8 |
Mike
Don't turn down a good pick up door.You can make it into a suburban door as long as Your window frame is usable.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
05-16-2005, 01:22 PM | #9 |
Check out GMTrucks.org
How hard is it to convert the doors smokekiki? What do you have to do. I am in need of a passenger burb door since someone clipped my mirror and dented the crap out of it. My window frame is still good, and I have a couple good pickup doors around. I haven't looked at it much, but it is just cutting some spot welds or something?
05-16-2005, 01:47 PM | #10 |
Mike
This is for the front 2 doors.Look where the window frame goes into the door.You will see the spot welds.Get a close measurment,so you have a good idea were the frame should go.Drill out with a spot weld cutter.Pull the window frames out.Put the suburbans frame in the door.You might want to place the door on the suburban,and get it lined up were it fits the way you want it before any welding.Put the window frame the way it fits,and tack in place.When happy with the fit weld it.Is there any structural damage,or just the skin?
05-16-2005, 06:12 PM | #11 |
Thanks for the info.
Just the skin is dented. I have toyed with trying to take out the dent, but when the mirror came off it tore some decent holes in the skin too. I guess I could reskin it, but that sounds like more work than swapping out the window frames. |
05-16-2005, 06:48 PM | #12 |
Scrubby,
DO you any pics of your door? If you decide to go the truck door route, I might be interested in your damaged door. Rob
05-17-2005, 03:13 AM | #13 |
When I first pulled up and posted to this thread, the pic of your burb didn't come up.
That is a beautiful burb! Great color.
08-15-2005, 07:51 PM | #14 |
try frank in olympia wa 360-956-7170
08-15-2005, 10:09 PM | #15 |
There is an NOS door on ebay. Not sure if it is the one you need.
Mike |
