Old 05-15-2005, 07:50 PM   #1
lamar
lamar's Avatar
Throttle Cable Help
Ok I have 350 w/ 700R4 trans, Holley 600 Carb. My problem is that the throttle cable is twisted coming out of firewall, because it's to long now that I have the correct bracket for the trans kickdown cable. Is it adjustable, the part that holds in the firewall and in the bracket have what looks like an ajustment but I'm not sure. Thanks for any help.
72 C-10
lamar is offline   Reply With Quote
Old 05-15-2005, 09:45 PM   #2
lamar
lamar's Avatar
Any body have any ideas or ever have this problem? The throttle seems to hang up at about 1200 rpms, when it does I just pat the gas a little and it lets go.
72 C-10
Old 05-16-2005, 12:38 AM   #3
CHEVIBUBBA
got boost?
CHEVIBUBBA's Avatar
you may need to use a seperate bracket for the throttle cable.
dunno 'bout adjusting the one you have.
'70 chevy lwb w/'67 hood.
357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada.....
'82 honda v45 sabre"the black"
CHEVIBUBBA is offline   Reply With Quote
Old 05-18-2005, 11:34 PM   #4
lamar
lamar's Avatar
Anybody have any ideas?
72 C-10
Old 05-19-2005, 08:00 AM   #5
72MARIO
72MARIO's Avatar
You can get Lokar throttle cables that you cut to length Looks really trick. That might be what you need if the curve bothers you and is binding when the gas pedal is depressed. My throttle cable curve on my 84 that's just the way it is.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 05-23-2005, 11:25 AM   #6
72MARIO
72MARIO's Avatar
Oky,
I see what you mean. I just Installed my 600 Holly with the correct bracket that bolts to the rear bolt on the carb. I think we need to get a cut to fit throttle cable. Have you come up with anything?
2005 TAHOE DD
