05-15-2005, 07:51 PM | #1 |
i love summertime
both trucks acting up-same problem-wtf
has anyone ever heard of this with these 67-72s? both trucks run good but once and a while i jump in either the 67 or 71 and turn the key and nothing. its like the battery is completely drained. but it ran fine and started fine 10 minutes before type thing, friday night i was getting gas in the 67 and went to leave the gas station and i turned the key and nothing. i pushed it into a parking stall and got a buddy to come give me a jump, we went to his work and tested the battery/alt/starter and they all checked out fine, same with the 71 gmc, about a month ago it did the same thing, wouldnt start so i just went into the mall and killed time went back out half an hour later and it fired right up...what gives? anyone have any ideas? both trucks have hei too if that makes a difference
thanks, Derek
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
05-15-2005, 08:18 PM | #2 |
Mine Does it once in awile, but I've never had to jump it. I just keep turning the key on and off and it will finally go. Got to be in the ignition switch.
-Cory 1967 2 Wheel Chevy |
05-15-2005, 08:54 PM | #3 |
Are you running headers or the exhaust real close to the starters? Just wondering if the starters are getting too hot?? Then when you wait a while after they cool down then they start. Just a thought!!
70-Olds 442 66-Impala 4-dr. 67-K-10 87 Chev. 1/2 Ton 4x4 Swb |
05-15-2005, 08:58 PM | #4 |
check your ground, solinoid for heat, and your ignitian switch
05-15-2005, 09:05 PM | #5 |
Got good Grounds ? That is a big problem with alot of old truck like ours. You did have the cab off the 67 right ? Did you reinstall the ground cable from the front floor support to the cab mount on the frame ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
05-15-2005, 09:59 PM | #6 | |
C10 Junkie
Good luck
09 Chevrolet HHR --- Cruck --- cross between a Car and a Truck Former rides: 1967 C10 LWB 1972 C10 LWB 1969 C10 LWB (parts truck) |
05-15-2005, 11:46 PM | #7 |
i love summertime
no headers on either truck, do you guys think starters get hot from ramhorns? ill check all my grounds to make sure..thanks
05-16-2005, 12:14 AM | #8 |
Put a remote soleniod (Ford) on it-problem fixed.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
05-16-2005, 12:28 AM | #9 | |
YES_____NO
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984 Help support the board |
05-16-2005, 12:41 AM | #10 |
got boost?
get a rope!!!!
'70 chevy lwb w/'67 hood. 357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada..... '82 honda v45 sabre"the black" |
05-16-2005, 01:32 AM | #11 |
I used to have a '69 gmc that would A) not turn over, like a dead battery. Or B)die while driving. Turned out to need a good cable cleaning at the battery. May not help, but its quick, easy, and free.
I think the world needs a drink... Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
05-16-2005, 02:06 AM | #12 |
Member since 2000
I had the same problem...........it was my starter. After a new starter and a shinny new heat shield it didn't give me any problems. . Best thing to do when this problem happens again is take test light and test all the wires on the ignition switch.
05-16-2005, 02:11 AM | #13 |
Thats the Hillbilly way
I had that problem awhile back it was the Battery ground cable .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
05-16-2005, 05:40 AM | #14 |
Derek. ^ what they said & my 69 did this at a gas station once just after I first bought it. I was right next to the Chevy dealership and I borrowed a battery teminal brush from one of the mechanics, I cleaned the battery posts & the cable ends put them back on and it flashed right up. Doug
05-16-2005, 05:44 AM | #15 |
IGN. switch contacts have a lot of use and may be worn out or corroded and do not make GOOD contact all the time.
1968 Chevy 4x4 307 4 speed Last edited by GMC AMI; 05-16-2005 at 05:47 AM. |
05-16-2005, 07:52 AM | #16 |
user # 2756
I second the ignition switch, just replaced mine in the 71, doing the same thing.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
05-16-2005, 08:21 AM | #17 |
Still Green but learning
I had a F*&D Bronco that had an issue like this, after driving I would try to start it and nothing. In my case these guys were correct, it was heat. A trick to find out if it is the heat was shown to me by an old man at the gas station I was stuck at. Get a cup or 2 of cold water and slowly pour it over the starter. This will cool it off and if heat is the issue it should start up.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
05-16-2005, 08:48 AM | #18 | |
1968 Chevy 4x4 307 4 speed |
05-16-2005, 08:49 AM | #19 |
My truck did the same. I changed the ignition (key) switch and it has not done this since.
05-16-2005, 09:16 AM | #20 | |
05-16-2005, 10:14 AM | #21 |
Msgt USAF Ret
All the posters have given good suggestions. Anything to increase the voltage to the solenoid will help the problem. If it occurs intermittently then one or all of these solutions will fix it. If it only happens after it is warmed up then Jhow66 is right and I agree with him that your starter solenoid is getting heat soaked and and you can either replace it and get a heat shield or get a remote solenoid .
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-16-2005, 11:07 AM | #22 |
Jumping from bat post to s post is NOT a good idea. If for whatever reason you go to ground (ie touching the starter body) you blow the voltage regulator. (Did it 2x I know)
