Old 05-15-2005, 10:52 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
72 GMC rear bumper brackets mount at an angle??
Do the rear bumper brackets mount at an angle or just lay flat in the frame rail? I have the chrome sport bumper. It's not a step bumper.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 05-15-2005, 11:07 PM   #2
72MARIO
72MARIO's Avatar
Angle.
front of the bracket up.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 05-15-2005, 11:10 PM   #3
69 Short Fleet
The 4 sport bumper brackets (2, inner) go straight out in-line with the frame rails and then bend 90 deg. and rest flat parellel to the bumper. The outer brackets (2) bolt flat against the inner brackets and then bend outward at a 45 deg. angle and go toward the outer bumper bolt holes they then bend once more to rest flat against the bumper. I found that they are not an exact fit so you may have to "tweek them a bit" (the out brackets). One thing I've found is be VERY careful tightening the bumper bolts as you can wind up bending the bumper bolt hole locations (on the bumper itself, front one also) as the metal on the bumpers is a LOT softer than I first anticipated. Hope this helps, Doug
69 Short Fleet is offline   Reply With Quote
Old 05-16-2005, 10:56 PM   #4
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I looked at a Chevy rear bumper bracket with the same bumper as mine and the inner (longer) bumper brackets were mounted at an angle.
Old 05-17-2005, 04:24 AM   #5
69 Short Fleet
Hmmm, I've never seen that before (for a sport bumper). Do you have a LMC truck parts catalog? It shows it quite clearly, I don't have a pic from it but maybe someone will post one. Doug
