Old 04-07-2002, 10:35 AM   #1
71-4x4-bb482
Post Got it from behind on ebay
bought a posi diff as for corp 12 bolt, advertised as corp 12 bolt, everyone thought it was corp twelve,buttttttttt guess what, its not, evrything looks corp 12 bolt but its a half inch too wide to fit into housing .Im workin on a pic any ideas Thanks
71-4x4-bb482 is offline   Reply With Quote
Old 04-07-2002, 11:16 AM   #2
fine69
fine69's Avatar
Post
Have you tried to return it? If something is not as described you should ask the seller to take it back first. Explain to them what the problem is. I have done this and had some success. Got a link to the auction? Someone here should be able to tell you what it is for.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 04-07-2002, 11:23 AM   #3
71-4x4-bb482
Post
I plan on contacting the guy I got it from, but i dont expect much luck. I,ll probly get a id on it and resell it
Old 04-07-2002, 01:05 PM   #4
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
Is it for a regular 12 bolt truck rear end? If it is check and see if it is a 4 series. I would be interested. E-mail me if you want to do that.
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 04-07-2002, 01:16 PM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Post
From what I have gathered from all the information I have seen is that the possi requires a larger housing than the non-possi. So if you are trying to put a possi into a housing that is a non-possi housing it won't fit. I am not an expert on rear ends though, this is just what I have heard. WES www.ClassicHeartbeat.com
Click (Here) to visit our on-line catolog.
E-mail me WEHEPP@attbi.com
72 BB Chevy Blazer
72 BB Chevy Short Fleet
72 SB 3/4 Ton 4X4
72 SB 1/2 Ton SWB 4X4
70 BB Chevy Short Step
70 SB Chevy Short Fleet
69 SB Chevy Short Step
68 SB Chevy Short Step
68 BB GMC Long Fleet
67 GMC 1/2 ton Panel
"Founder" Classic Heartbeat Pickup Club
Olympia, Washington's "Home For Wayword Chevys"
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 04-07-2002, 01:56 PM   #6
71-4x4-bb482
Post
Wes you described my problem to a tee, I have a non posi rear,trying to install a posi unit into it I thought the width differance was internal in the diff, not in the rear housing, ooooohhh man
Old 04-07-2002, 02:20 PM   #7
mooneyes
mooneyes's Avatar
Post
the last truck i had i changed a non posi rear to a posi using a factory posi unit..had no trouble..so now u got me interested in what that thing is for
70 short step from vegas woo hoo !!!Ken Lyons Slippery Rock PA yahoo messenger:mooneyes4b "things always look different from higher up" Clint Eastwood (fist full of dollars)
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 04-07-2002, 11:06 PM   #8
texnician01
texnician01's Avatar
Post
Any Carrier for a 1/2 ton rearend will fit in any half ton rear end. Posi or not. i'm guessing but You may have a 3/4 ton posi. I havn't messed with the 3/4 ton's but I just did all kinds of work on my half ton and swapped between any GM 12 bolt to any other GM 12 bolt. Until somewhere around 86-88? all of the half ton rear axles were the same guts 2 or 4 wd.
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
05 Harley Night Train
06 1200 Sportster (Wife's bike)
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
texnician01 is offline   Reply With Quote
Old 04-11-2002, 04:58 PM   #9
texnician01
Post
ttt
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
Old 04-12-2002, 10:43 AM   #10
texnician01
Post
I've done some checking around and havn't found much. I'm starting to wonder though, could this be a dodge carrier? Eaton surely made carriers for companies other than GM right? just an Idea still checking on the casting ##'s.
1969 C-10 292 I-6 4 spd in the middle of a restoration. going to get a 327 and 3.07 gears but keeping all of the original parts so I can put it back to original later on down the road.
55 chevy 4 door 150
47 Willys CJ-2A
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
Old 04-12-2002, 10:53 AM   #11
rustfree
Post
here's my 2 cents..I have heard that there are two sizres of housing dependent on the ratio going in. The diffs for 3.07 up to 3.73 (I believe) is smaller than a diff for the 3.90 to 5.12 gears..at least that is what I've heard. BTW I had a 3.42 posi put into my non-posi 3.07 without a problem
72 swb cheyenne super 350/350
69 cst20 BB longhorn
Warren, OR
rustfree is offline   Reply With Quote
Old 04-12-2002, 11:45 AM   #12
Blazer1970
Blazer1970's Avatar
Post
The carrier is different for high and low gear ratios, but all 12 bolt truck housings are the same, and any carrier will fit in any housing, posi or not. The difference in the high and low ratio carriers is that the mount for the ring gear is offset more on the higher ratios to allow for the bigger diameter pinion gear.
Blazer1970 is offline   Reply With Quote
Old 04-12-2002, 04:59 PM   #13
texnician01
Post
http://pic5.picturetrail.com/VOL83/5...66/8792565.jpg
http://pic5.picturetrail.com/VOL83/5...66/8792572.jpg
lets see if this works
good works like a charm now you can see the difference in the carriers. the one on the left is a 12bolt chevy truck carrier and the one on the right is the one in question.
[This message has been edited by texnician01 (edited April 12, 2002).]
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
