Old 05-16-2005, 01:17 PM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
fan question
ok...i have a 67 short step with a 400 SB in it...wont be doing any towing probably wont be driven on any real long trips or anything but when it is driven will be driven hard. my buddy has a 87 shortbed 305 4wd truck that tows a i think 30 foot horse trailer....and they also have a 85 GMC truck with 350 4wd that tows the same horse trailer...both of those are driven pretty hard....now to the point at hand...the 87 recently sliced a rad house on the fan so when we replaced it we had a electric fan out of some little car laying there so we decided to put it on...with the mechanical fan it got 8 MPG just driving around....with this electric it got 9.9 towing the trailer...so we are gonna buy electrics for all our trucks...not only for that reason...the mech fan gets im my way looks ugly etc etc as well. but the question is...what kind of CFM can a 5 blade clutch fan put out? and what CFM do i need for those trucks mentioned above...im looking at a 2400 and some 2750s...the 2750 is roughly 15 bucks more each than the 2400....sorry for this being so long.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 05-16-2005, 01:42 PM   #2
67ChevyC10Stepside
also should a fan shroud be used with electric fan?
Old 05-16-2005, 04:06 PM   #3
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
my friends dad took an electric fan out of a mid 80s firebird/camaro and it fit right inside the fan shroud on his 75. he just drilled 4 small holes every 90* and zip tied the fan in. i wouldnt use those pull through zip ties that come with electric fans. they mess up the fins and look like hell (JMHO) i made my own shroud out of sheet metal and it works (with a 16"), but would be better with it centered (i couldnt center it cause of the water pump) or with 2 12".
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-16-2005, 04:39 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
HOW MUCH YOU LOKKING TO SPEND
REASON I ASK, WE DISCUSSED THIS IN GREAT
LENGTH AT THE PIGEON FORGE SHOW WHILE
LOOKING AT DIFFERENT EXAMPLES IN TRUCKS
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-16-2005, 04:41 PM   #5
67ChevyC10Stepside
im not sure on money wise....im just looking for CFM requirements right now...then i'll go from there.
Old 05-16-2005, 04:50 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
PM "SEE_TEN", HIS SET-UP IS THE BOMB, JMHO, AND THE ONE I
AM GOING WITH IN THE NEAR FUTURE, HIS ARE VARIABLE SPEED,
AND ON HIGH COULD SUCK A SMALL CHILD THROUGH THE GRILL
IT COVERS THE WHOLE INSIDE OF THE RADIATOR, COMES WITH
EVERYTHING, HAS 2 FANS INSTEAD OF ONE, FANS ARE FLEXLITE,
ALSO HAS ADJUSTABLE THERMOSTAT, ETC.... HE SAID IT CAME
FROM SUMMIT, SERIES #295 IS WHAT HE TOLD ME, $369.99
(HE HAS THIS SET-UP ON BOTH OF HIS TRUCKS AND HIS JEEP)
http://www.jegs.com/cgi-bin/ncommerc...50&prmenbr=361
COMES W/ THE UNIT BELOW AS PART OF THE KIT LISTED ABOVE
http://www.jegs.com/cgi-bin/ncommerc...51&prmenbr=361
Old 05-16-2005, 07:18 PM   #7
67ChevyC10Stepside
i dont want to spend that much....all im looking for in this thread is how much CFM i need.....i can have aluminum mounts tig welded up and everything else i need will wire it myself etc...just need to know what cfm size i need.
Old 05-16-2005, 09:53 PM   #8
67ChevyC10Stepside
of all the people on this board noone can tell me what kind of CFMs i need?
Old 05-17-2005, 10:33 AM   #9
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Quick look at the flex-a-lite site yielded this: http://www.flex-a-lite.com/heavy2/spec/spec.html
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
