Old 05-16-2005, 02:29 PM   #1
Edmond
Edmond's Avatar
Question Dana 60 a direct bolt-on?
Since I have my truck I have had this Idea of swapping my current rear axle (Eaton HO52) for a Dana 60.
Now I have had some info on this seen before on the board, but with the search not working
I can not find it any more. (I know I should have saved it on my harddrive )
If I can find a Dana 60 axle (Which will be a difficult task on it's own ),
will this be a direct bolt-on under my 71 C/20 Longorn? Or are there miner things to rebuild?
Has anybody did this, and can post some pictures?
Thanks in advance.
Cya,
Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
The Netherlands
Edmond is offline   Reply With Quote
Old 05-16-2005, 05:16 PM   #2
68 50th
68 50th's Avatar
Edmond,
I just e-mailed you some pictures of my Dana rear axle.
Hope someone on here can help you out with some answers.
TTT for you.
Mats..
1971 Cheyenne Super Custom Camper 475CBB/TH400/AC
1992 Silverado Sport Truck
1988 Silverado 2500 Ext Longbed 4x4
2001 GMC Sierra SLT 4x4
1990 Chevrolet K3500
1965 Pontiac Grand Prix
1980 Z 28 350/4-speed/AC/T-top
1980 Camaro Coupe V6/3-speed
1979 Buick Century Wagon
68 50th is offline   Reply With Quote
Old 05-16-2005, 05:20 PM   #3
Edmond
Edmond's Avatar
Originally Posted by 68 50th
Edmond,
TTT for you.
Yep, just seen the pictures. Thanks very much.
Now at first glance it looks the same, but I will check tomorrow, to compare the pictures you've made.
Thanks again.
Cya,
Edmond
The Netherlands
Old 05-16-2005, 05:35 PM   #4
jtminton
II Timothy 4:2
jtminton's Avatar
Edmond,
TTT for you.
Any way you can post some? I'm curious, too.
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus"
MY TRUE PRIDE AND JOY
"Dangit, Bobby, people will see that oil stain and think I'm a drunk."
jtminton is offline   Reply With Quote
Old 05-16-2005, 05:57 PM   #5
68 50th
68 50th's Avatar
Here is some pics from my 71 C20 with Dana axle.
Hope it helps.
Mats..
Old 05-16-2005, 05:59 PM   #6
68 50th
68 50th's Avatar
More pics.
Mats..
Old 05-16-2005, 06:00 PM   #7
68 50th
68 50th's Avatar
And more
Mats..
Old 05-16-2005, 06:01 PM   #8
68 50th
68 50th's Avatar
And the last two
Mats..
Old 05-17-2005, 02:36 AM   #9
Edmond
Edmond's Avatar
Thanks for the pictures, and back TTT
Cya,
Edmond
The Netherlands
Old 05-17-2005, 06:04 AM   #10
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The spring spacing for these year trucks is either 40" 4wds and C30s or 42.5" 2wds. I have a 71 dana 60 from a C20 in my garage w/ 42.5" and the dana60 in the rear of my K25 is 40". These are leaf sprung axles. They are the same over all width. Too bad you weren't closer I'd sell you the dana 60 in my garage.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-17-2005, 07:40 AM   #11
Edmond
Edmond's Avatar
So you think it should be no problem swapping a Dana 60 for my old Eaton HO52?
If anybody has ever done this swap please let me know.
Thanks.
Cya,
Edmond
The Netherlands
Old 05-17-2005, 09:29 AM   #12
jtminton
II Timothy 4:2
jtminton's Avatar
Did they ever make a coil Dana 60?
Old 05-18-2005, 07:18 PM   #13
da-burb
"Ochre Ogre"
da-burb's Avatar
jtminton, they did make a coil Dana 60. I have several.
Edmond. Unless the Dana you find was in a big block Longhorn you will need to make some modifications for it to work. I sold a Dana 60 with 3.54 rears to someone that put it in his longhorn. I know he had to weld on new spring perches, and change the driveshaft length. I also think he had to change the shock mounts to a new location. It wasn't difficult and he is very happy with the swap.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 05-19-2005, 12:28 AM   #14
Edmond
Edmond's Avatar
Thanks for the info.
I deceided to do something else. I'm going the disc conversion way like in this thread:
http://67-72chevytrucks.com/vboard/s....php3?t=154617
This way I get to keep my own axle with the NoSpin diff and have it much easier when checking the brakes.
Cya,
Edmond
The Netherlands
Old 05-19-2005, 09:18 AM   #15
jtminton
II Timothy 4:2
jtminton's Avatar
Well, if you ever happen to be driving around Fort Worth with one in the back of your truck, let me know.
