06-14-2002, 05:00 PM | #1 |
filled drip rail
My drip rail is filled with a type of clear silicone. What is the best method of removing it? This is probably why the upper part of the cab is in such mint shape. All suggestions are welcome
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
06-14-2002, 05:09 PM | #2 |
Half a bubble off!
Probably some type of chisel Dube, just be careful. I had the guy at the body shop re-do my front rain gutter with some stuff he suggested (and it has held up perfect so far), but he filled it so much that when I recently went to add chrome gutter trim, it would not go on. Just something to think about, a lot of people will never use that trim, but after seeing it, I thought it would look good on my truck, and it would have if I could have got it on. Oh well, live and learn! Good luck!
Just call me LB. '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
06-14-2002, 07:02 PM | #3 |
Try a wire brush on an electric drill or air dremel tool. Use safety goggles!
06-14-2002, 10:17 PM | #4 |
Flamin' Bass
I'll go a little off topic and ask another question:
How much should the drip rail be filled? When I bought my '67 C-10 the rails were FILLED with layers of some kind of sealer. Probabily 3/8" or more thick. The Chevy Assembly Manual calls for 3/32" X 7/16" but that just barely covers the seam at the bottom and you can still see all the spot welds. Going thicker you gotta put a layer on and wait for it to set up; then apply another layer. All the time trying to keep the whole thing smooth.
Rick Olson /nosto/ Galloway, NJ Pics : http://community.webshots.com/user/nosto53 1972 Triumph TR6 - full resto, now with a Toyota 5-speed 1975 F**D F-100 - rusty, but reliable 1982 HD XLH-1000 1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!! |
06-15-2002, 12:59 AM | #5 |
Auto body seam sealer is the thing to use,and a wire brush on air or electric works best to remove the old sealer.
A container of lacquer thiner to dip your finger in as you smooth it out works great. Dip your finger often,wiping them on a rag every now and then will help keep the job clean.You need to wear heavy duty latex gloves with smooth finger tips. Let the job dry completely before primering it. Chevyman 68 C/10 |
06-15-2002, 01:03 AM | #6 |
The thickness shoud be enough to cover the seams and come out smooth.
