Junior Member
![]() Join Date: Jan 2005
Rear Leafs - are 70's the same as 73's?
I have a 70 with rear leafs and I want to flip kit the rear but I've only been seeing kits for the 73 and up trucks. Will these work or are the leafs different in some way?
Andy |
Nope your leafs are wider (or visa/versa). Check with any of the board vendors or ECE. They have the flip kit for 67-72 leafs.
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
Junior Member
Are you sure about that? My ECE catalog doesn't have a flip kit for 67-72 and I've looked at a bunch of the vendor sites and found nothing there either. All I've seen is the flip kits for 73 and up.
Registered Smarta$$
DJM has flip kits for trucks 63-72
63 GMC custom going to be slammed ![]() ![]() |
Junior Member
Thank you. I had not checked the DJM site.
That's new to me too. I went with a drop shackle and Dearched springs. To get a 5" + drop.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Junior Member
How does it ride with the dearched springs? I need to look into that as an option. Did you C-notch the frame?
Andy |
Registered Smarta$$
how much did it cost to dearch your springs?
I have not driven it yet. Should be on the road in the next month at most.
I think it's going to ride really nice. It has to ride better than stock being closer to the ground. I have drop shocks desigend to work with a 6" drop which will also help out. Just need to find a set of hedders that the collectors wont get ripped off. I have a set of Chevelle shorts but the hit the motor mounts. I am either going to cut the hedders and make em fit or get a set of motor mounts from Norhtwest Auto Fab. Then finish up th ebrake lines and I can take it for a ride. 4 yearsin the build up I cant wait to drive it ! The spring work costed me $115 Cdn. That included 4 new bushings pressed in. The dearching was like $20 per side. I took them the spring pack in and told them to take 3" out of them. The said no problem. No notch here. I have around 3" between the frame and axel and the rubber bumper is about 2" from hitting the frame. The is a member Powell72 he has a 6" coil drop and has 2.5" between the frame and axel and he had no complaints. I personally would not feel good about riding around with a bolt in notch. I would rather smack the rubber bumper off the axel. Mabye this winter I might weld in a C notch but I would want to box the frame in from in front of front hanger to behind the rear hanger.
Divorced .....WITH KIDS
i took my truck to Deep South Springs to have my leaf springs dearched. They lowered the truck 4 inches around 2 years ago and i have not had a problem . The truck rides fine but I have not tried putting a serious load in the bed.
1969 GMC SWB 1975 Chevy Malibu 80k 1963 Ford Galaxie 63k (inherited) 2005 Nissan Armada (wife's idea) |
Chevy Nuttttt
I just put a 75 rear end under my 67 and welded new spring mounts on the bottom of the housing. no kit req just a torch and a welder.
67' Chev swb step side 69' SS elky 03' Chev ext cab 4X4 hey who lernt me to spell ![]() ![]() Last edited by Super Duck; 05-18-2005 at 08:21 PM. |
I think that Dearching the springs would show the load alot sooner than with the stock contour.
