Old 05-16-2005, 10:26 PM   #1
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
2wd coil spring help
72 front hd coils how much do i cut to get 3in drop and do i cut top or bottom.thanks
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 05-16-2005, 10:51 PM   #2
72BLAZERDUDE
72BLAZERDUDE's Avatar
Turn the spring over an cut 1 coil from the bottom. Dont be tempted to cut two. Cut it directly below where the original end of the spring is. that way it will sit back in the pocket correctly in the lower a-arm. One coil is a shorter spring but also able to support less weight so a smaller compressed height. One coil should be 2 1/2 - 3 inch drop.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 05-16-2005, 11:15 PM   #3
72shadetree
KEEP ON TRUCKING
thanks
72 cheyenne 2wd lwb
71 k20 sons
bassett va
