Old 05-16-2005, 11:45 PM   #1
CAJ68
Give Me The Signal
my signal lights work at the bulbs, but the green arrows don't work in the dash. bulbs are good all other lights work fine. what could be my problem? also my cluster doesn't have the gauges, just idiot lights. what is the process to change to the cluster with full guages? thanks.
CAJ68 is offline   Reply With Quote
Old 05-16-2005, 11:50 PM   #2
shifty
Questionable
shifty's Avatar
There are some wiring changes you need to do before plugging in a full cluster (or tach dash) versus the 2-gauge cluster with dummy lights. This is explained in a thread in he FAQ forum.
As for the problems with your lights, one of my blinker arrows is out right now. If you pop out your dash, there is a circuit sheet on the back. remove the corrosion and look for burn marks on the lines or detached sections of the copper lines. It's one big loop - and if you have a burn in the line, all bulbs after that one will not work.
You can buy a replacement circuit sheet from most of the board vendors.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 05-17-2005, 07:05 AM   #3
byrd
Union Electrician
byrd's Avatar
I have a good 2 gauge printed circuit, if you find that is your problem. Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 05-17-2005, 07:36 AM   #4
cantontruck
cantontruck
I replaced the bulb holder and cleaned the contacts on the circuit board. Fixed problem.
cantontruck is offline   Reply With Quote
Old 05-17-2005, 04:57 PM   #5
CAJ68
Thanx For The Info , I'll Try A Good Cleaning And Check The Circuit.
