go cyclones
Radiator Problem
My radiator leaks so badly now that when I fill it up that it will pour out with a stream that is a little bigger than an 1/8" in diameter. Obviously it doesn't take very long to drain and it is inside the four-core about one third up from the bottom. Is this terminal? Should I take it to some one to fix or go ahead and cough up the $180 for a new one?
Thanks |
um... around here(creston IA) its free to have them look at it and tell you if its ruined or not, so i would take it in. chances are that if it is that big of a leak and nothing was pushed through it, then it is bad, probably rotted through. where are you looking for a replacement?
Ryan |
Mike
What caused the hole?If it is corrosion,I would look into another one.I don't know what it would cost to rebuild.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
I have a 3 row I would sell "cheap" if you can wait till the 27th, -will meet someone there (Des moines) to pick up a truck. If not -ok -I just have a few sitting around probably to good to scrap.
67-72 Addict!
I just bought a 4 row off ebay for my dads truck brand new with a lifetime warranty for $138 plus $15 shipping. Took 2 days to get it. I just called the number in the auction with a credit card. The company has them on there everyday. Here is the link:http://cgi.ebay.com/ebaymotors/ws/eB...category=33602.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
There is a product called Bars Leak that has worked for me to stop leaks in the radiators. There are others also but that is the one that comes to mind.
If the radiator is corroded then a new one is in order. Being inside the outer row of cores makes me wonder what caused the hole. It is possible to pull that tube and solder the openings in the top and bottom tanks. You lose one tube and maybe the one on the outside of it but with a four core that won't affect cooling capacity. Find out what caused the leak and go from there.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#7 | |
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
Curious -What brand are the radiators they are selling on Ebay? A good price for a 4 row around here is about $150.
![]() Join Date: Jul 2004
The one I got off ebay was a 4 row Modine with the heater outlet. Paid about 135 and they brought it to my house for 15$. Came from radiator.com or radiator express.
go cyclones
For that price I think I will go with a new one, It is over thirty years old so it probaly be best to just get a new on. The leak started small and then got bigger so I would assume errosion.
go cyclones
oh and thanks for the info
They originally sent me a 3 row without the heater outlet. It was a cheap one made in Brazil or someplace. I called them and told them I needed the heater outlet and they sent the really nice 4 row Modine. No extra charge. Just something to be aware of. They are really easy to deal with.
#13 |
I have bought Modines and GoDans (spelled right ??) and had all Good luck.
#14 |
for all you guys with no money for a new radiator or to pay to get one fixed. i had a rock go through mine once. i filled the hole with rtv sealant and put in a can of black pepper. drove for another 2 years. poor boys got poor ways
#15 |
Cause the Chicks DIG IT!!
Yes The www.radiator.com people are very easy to work with. thats where I bought my 4 Core at for cheap and have not had one problem with it. as far as the bars leaks and the pepper trick goes these should be used as mere quick fixes until the problem at hand can be fixed. These items build up to clog the hole but also build up in other areas you don't want them.
