Old 05-17-2005, 04:03 PM   #1
stan79chevy
stan79chevy's Avatar
700r help
my buddy just rebult his tbi in his 87 chevy 4x4, it has a 350 700r4 and a 208 case its half ton. after he rebuilt his tbi the engine runs great now idles fine and everything. but the transmission dont shift until its at a higher rpm than before and when it does shift it shifts really hard <chirps the tires if your getting on it>. are there vaccume lines or a wire or something that may be loose that would cause this? he was in and out of the engine compartment working on this could he have broken something? the fluid level was fine nothing made any weird noises or anything. i had to leave so we didnt have anytime to check anything out and his back is out so he cant really look himself. thanks
stan
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 05-17-2005, 05:51 PM   #2
Jonboy
Slots go on anything!
Sounds like the TV cable is either not hooked up or is out of adjustment. I would check that first.
1974 Jimmy- 5.3/4L80e/NP241
Old 05-17-2005, 06:49 PM   #3
bigarmzz
bigarmzz's Avatar
(what he said)
i second that opinion
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 05-17-2005, 08:10 PM   #4
86k10
TV valve could also be a little sticky. Check adjustment first and if that's ok, then with the engine off, mash it to the floor as hard as you can real quickly about 4 or 5 times. That will 9 times out of 10 unstick it, might take more than one try but usually not.
98 Neon
97 Grand Prix GT
02 Grand Prix 40th Anniv.
86 GMC 5.0
77 Olds 98 6.6
REAL AMERICANS, DRIVE AMERICAN
86k10 is offline   Reply With Quote
Old 05-18-2005, 08:04 PM   #5
86 GMG
Yah Pretty Much It Sounds Like The Tv Cable 700r Are Funny Lick That. Dont Drive It Much Until You Fix It Inless You Want To Rebuild Tranny
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
