Body Mount ?
The truck I'm doing is pretty much rust free, but I know that the body mounts are most likely shot. I don't want to remove the body or bed, so can you lift up, just enough, to install the mounts one at a time? After changing the mounts, can you tell the difference in the way the truck rides?
thanks.....
1997 GMC Sierra Ext 1965 Mustang |
Pull the cab mount bolts out of one side, lift that side up with a floor jack, remove and install new ones, lower jack enough to get the new bolts started, lower jack completely and tighten, then do the same for the other side.
