Old 05-17-2005, 11:31 PM   #1
chipflyer
chipflyer's Avatar
console install question
I am installing buckets and a seatbelt style console in my 71 and I have a couple of questions.
1. Can I use the original front bench seat outer mounting holes or should I move the seat out an inch and drill new holes? Seems like there was a how to post on this but with no search function and dialup I am really hoping someone will know.
2 I have the bracket that attaches to the front of the console but is it needed on our trucks? It almost seems like the front would be mounted to high with the bracket attached but if you didn't use it the cutout in the console would sit on the floor channel pretty good. Was the bracket just used on blazers?
Any help would be greatly appreciated guys
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 05-17-2005, 11:58 PM   #2
boraxman
Keepin an eye out
boraxman's Avatar
I actually have the same questions as my buckets are sitting on the garage floor...so come on peeps
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 05-18-2005, 12:20 AM   #3
midyearvet@aol.
Console mounting
If you look on the raised portion (Rib) of the floorboards there are two dimples 5&1/8" apart>front mount holes. About a foot behind those are two dimples 8&1/2" apart> rear holes.
You need the center front reinforcement/nut plate to mount the inner bucket seat mounts & from there you can figure out the rest of the mounts
Seats should be centered on the glove box & the instrument panel.
You also need some wedge shaped brks. for the outer rear mounts. Almost impossible to find. I borrowed a pair to make some for mine.
Rick / Ca.
midyearvet@aol. is offline   Reply With Quote
Old 05-18-2005, 01:01 AM   #4
Carl71
Carl71's Avatar
Just did this today. Agree center on steering and glove box, center the console on the middle section. Found using the orignal holes made everthing to tight.. good Luck
1971 C10 longbed 327
1971 Shortbed 350
Indiana 46052
Carl71 is offline   Reply With Quote
Old 05-18-2005, 09:41 AM   #5
chipflyer
chipflyer's Avatar
I have the center nut plate but I don't think I can get it installed in the channel without raising the cab or dropping the transfer case. It sounds like I don't want to use the original front driverside holes, correct? Carl did you have dimples in your floor pan and did you use the console bracket? I do have the wedge shapped brackets also.
thanks
Old 05-18-2005, 10:27 AM   #6
trucks72
trucks72
trucks72's Avatar
bucket seat mount
There are dimples in the floor for the console. You just have to dril those and put bolts throught them. As for the seats, on the outside two holes where the bench seat bolted in. Measure 1 inch out to each the outside of those holes. Drill those two holes out. After you do that mount your console in place then put your buckets in the truck. Put a bolt in those two outside holes, the you can line up the front of the seat with the console to make sure they are straight. Afer you get that done you can reach under the seats to mark the other holes.
trucks72 is offline   Reply With Quote
Old 05-18-2005, 12:01 PM   #7
midyearvet@aol.
Nut plate
Loosen the body bolts on the drivers side. Remove the body bolts on the passenger side. Jack up body 4 inches and you can slide the retainer plate right into place over the right frame rail and over the transfer case.
Rick / Ca.
Old 05-18-2005, 12:54 PM   #8
chipflyer
chipflyer's Avatar
Can I do that without screwing up anything on a finished truck? I assume you mean to loosen the front fender mounts also and raise the whole side, correct?
Old 05-18-2005, 04:48 PM   #9
midyearvet@aol.
Installing bucket seat nut plates
I just completed mine. I don't have the front end on it at present.
You should probably undo both core support bolts & maybe fan blade & then watch everything as you raise passenger side of body. I did not undo steering or brake lines. Thats why you lift pass side. Everything is on drivers side.
Rick / Ca.
