Olds engine casting number question ?
Hi all ,
not truck related , mhh ? yes , it is... I have a friend which parts regularly out Chevy from the 1970's/1980's , I've been at his workshop yesterday... He has some Oldsmobile engines laying there around , as I want to change the anemic 260ci Olds engine I have in my Burb , I could identify some 350ci's which interest me a lot ( casting number : 557752 3B ) , on the hand of that list : http://www.butlers-a1.com/oldsm.htm but there are laying other Olds V8 engines with the casting number : 790 GM5 , which come out of Chevy's Caprice Classic Wagons from the beginning of the 1980's ????? ![]() ![]() I did a search on google , but was completely unable to trace that casting number... Has anyone of you a link to that information ( cubic inches ? ) Thanks the Baron
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016 1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D. 1960 Girl Friend , frame still good , body has some dents Last edited by the baron; 05-18-2005 at 08:22 AM. |
Insert Witty Text Here
I don't have any info on the casting number, but I can sure sympathize with you regarding the 260. I had one in a Cutlass once, and the car could hardly get out of it's own way. I pulled it, and dropped in a 350 Olds. The difference was amazing.
I am remembering that Oldsmobile 307 engines came out in a lot of GM products in the early 1980s. Could it be one of those? Slonaker EDIT: Maybe this will help? http://www.442.com/oldsfaq/ofblk.htm "The 1977 and newer blocks will have the cubic inches cast in large raised numbers right above the right hand center freeze plug, eg. 403. The 307 will be in liters (5L), and a diesel engine will have the letters "DX" on it. The engine VIN letter will also be cast into the side of the block. Note that the 260 blocks sometimes have the last 3 digits of the casting number cast there, "355", which is rather misleading." Last edited by Slonaker; 05-18-2005 at 08:58 AM. |
#3 | |
I have already been on that site too , but they don't speak about casting numbers as you may find them on the other blocks ( number casted on the bloc , just on the rear of the water pump ) ... But I have to admit that I didn't look at the side of those newer blocks , I'll take a look in the coming days Thans for your answer... ![]() the Baron
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016 1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D. 1960 Girl Friend , frame still good , body has some dents Last edited by the baron; 05-19-2005 at 03:32 AM. |
if its 80+, i'd almost put money on it being a 307
Hi Jeremy ,
I guess you're right , but why did they put Olds 307 engines in Chevys Caprice Wagons ? ![]() I can't imagine a shortage of 305 by the Chevrolet plants ? by the way , I've been there with a friend who has a 1976 mid-size Buick with the 3.8 V6 , he has bought a 350 Olds to put in it , 350ci Buick engines are very tough to find here... ![]() he has paid 700€ for the engine , with all appendages on it ( alt , A/C compressor , carb , starter ) : not much money ! I have ordered my own 350 either , hehe ! ![]()
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016 1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D. 1960 Girl Friend , frame still good , body has some dents |
#6 | |
you mention a shortage of Chevy 305s, consider that they were put in C and K trucks, G vans, Monte Carlos, Malibus, Camaros, Caprices/Impalas, as well as some Buicks, Olds, and Pontiacs of the same vintage. a shortage of engines may not be that far off. since they were already tooled up for the other engines, they probably just upped production of them to fill the need. Cadillac also used the Olds 307 and Olds 350 Diesel in their cars, since there was no "Cadillac" engine at the time. |
