TACH reading 3 times higher
The tach on my '79 c30 454 is reading 2100 at idle and maxes out when I'm driving around. I thought this only hooked up to the HEI distributor. The wire looks fine, any help on this? Are there any other wires to look at?
Thanx in advance Dano
![]() ![]() It ain't yours, if you didn't build it! |
needin' money
check the ground, make sure it is grounded good , we undid the screw that held my ground on and the tach maxed out.
Garage Queen Material
what kinda tach is it? if its an aftermarket tach it possibly could have a setting for 4, 6, and 8 cylinders. it its set to a lower setting, it will do what you're saying.
but being as you have a c30, i'm guessing it has a stock tach in it? |
Stock TACH, where's the ground?
Dano
i'm not sure about the ground problem or if its something else. i dont know where the ground wire leads to on the stock tach, i do know that most of the stock tachs are not very accurate and need to be rebuilt. how long has it been reading off? has it ever read correctly?
Professional Grade
That is one of the signs of a tach headed south -- Reading too high... You can check out www.73-78.com for more information.
I hate to leave a plug, but I do have a spare one that'd look real nice in there for sale on the parts board, lol ![]()
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
needin' money
i believe he meant, www.73-87.com, i asked my auto service teacher, he said it's either a ground, which your going to have to look at wiring schematics to find out where it should be, or like Russell said it's about to quit
Professional Grade
thanks for the correction 82c10 -- I just type too fast for my own good, lol
Look above the left (drivers) kick panel .There should be a gang connector and the tach ground hooks to the top of it . It is just a female blade connector . The wire comes off of the instrument panel on the back side of the tach . There are only three wires , 12 v , Ground , and ignition which goes to the distributor . If you look under the dash you will see the wires . You might also want to check all of the under hood frame and body grounds . Frank
Thanx everyone! I'll look at it this weekend.
Dano
Chevys Kick A$$
My buddy had a stock tach doing the same thing for a little while, ground did not fix it and then it was shot. Got a nice aftermarket one and no problems since then.
-Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
#12 | |
What do we get for $10?
It's usually the first thing I look for when I see an interior pic. ![]() And yeah, I've seen them reading high when they're going bad.
1977 GMC K25 400/400/205 1989 Chevy Suburban R1500 350/700R4 (work beater) 1994 Chevy K3500 dually 454/4L80 1996 Corvette LT4 350/ZF 6 speed 2000 Bonneville SSEI Supercharged 3.8 Liter V6 1966 Chevelle 2 door sedan (Needs major repair ![]() Last edited by 77gmcjoe; 05-19-2005 at 09:33 PM. |
