Old 05-18-2005, 12:55 PM   #1
redz 1970 K5
OBS guy
redz 1970 K5's Avatar
Guys, really need help with some mirror measurements!
So the PO graciously filled in the west coast mirror holes, and I picked up a set of the smaller mirrors (thx drnk2mny). I need some measurements so I can get the mirrors in 'close to' stock position. My truck is far from a stock nor will ever be, so I am not looking for digital caliper accuracy; say within +/-1/8" would be great- just a tape measure should do it just fine.
Please, if someone could look at these pictures, and take these two measurements for me, I would REALLY appreciate it. I can drill the holes and get these puppies installed today.
Pic one- very front of mirror to front of door
Pic two- very top of mirror to top of door
88 Suburban
Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear,
Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more
redz 1970 K5 is offline   Reply With Quote
Old 05-18-2005, 01:36 PM   #2
70GMC_BOB
I have stock west coast mirrors on my 72 chevy. driver side 1) 6 5/8" 2) 2 3/4". pass side 1) 7 5/8" 2) 2 3/4". measured it twice because they were different. A quick not: The 2nd measurement was with the tape against the body, not vertical. I do not have the camera at work , otherwise i would take some pics for you.
1972 chev c20 2wd lwb 350v8/th350. (dad's)1970 gmc longstep (9ft commercial bed), 1 ton, 2wd, 350/th400.
70GMC_BOB is offline   Reply With Quote
Old 05-18-2005, 01:44 PM   #3
redz 1970 K5
OBS guy
Is the position of the west coast mirrors different then the smaller mirrors that I am trying to fit?
I thought the west coast mirrors were the larger ones that had two mounting spots on the door? Measurements might be the same, just wanted to confirm.
Thanks!
88 Suburban
Old 05-18-2005, 02:30 PM   #4
pjmoreland
pjmoreland's Avatar
I can get you the measurements tonight. Keep in mind that the passenger mirror mounts farther back than the driver side.
pjmoreland is offline   Reply With Quote
Old 05-18-2005, 02:57 PM   #5
hgs_notes
GEARHEAD
hgs_notes's Avatar
Here ya go.
HG
hgs_notes is offline   Reply With Quote
Old 05-18-2005, 04:40 PM   #6
pjmoreland
pjmoreland's Avatar
The bummer about this drawing in the assembly manual is that who knows where "20" and "35" are? I've got a driver door that has original mounting holes in it. I'll try to get some measurements tonight if you need them. The drawing does show that the passenger mirror mounts 1.3" farther back than the driver side.
Old 05-18-2005, 06:10 PM   #7
fire235
I was just about to start this same thread. I need the same measurements to mount the mirrors as well.
fire235 is offline   Reply With Quote
Old 05-18-2005, 07:15 PM   #8
Stroker
Maybe this will help. The penciled line is 1 inch down from the body line.
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 05-18-2005, 07:18 PM   #9
70GMC_BOB
my measurement od 6 5/8" was to the edge of the mirror like you show in your pics. you should be able to add the extra distance to the center of the hole. that will get you real close.
Old 05-18-2005, 08:18 PM   #10
JimKshortstep4x4
Talking
I just measured the two doors that have factory holes punched in them for the sport mirrors. The measurement from the front edge of the driver's door to the center of the single hole is 7". The same measurement on the passenger's door is 8" or 1" longer than the left door.
I use the gasket for locating the mirror, centering it on the mounting surface, mark the hole locations and drill the holes with a 11/32" drill. This gives you some adjustment room.
Jim
Old 05-18-2005, 09:24 PM   #11
redz 1970 K5
OBS guy
Good idea, and thanks for the help everyone!
88 Suburban
Old 06-23-2005, 03:41 AM   #12
Hart_Rod
Hart_Rod's Avatar
Are these measurements the same for a suburban?
Rob
Hart_Rod is offline   Reply With Quote
Old 06-23-2005, 12:17 PM   #13
Orange Truck
Orange Truck
Originally Posted by hgs_notes
Here ya go.
HG
Saw the drawing of the mirrors. Impressive! Is that same type drawing available for the OEM tripod mirrors used on 1969 Chevrolet C10 mirrors? If so how do I obtain copies? Thanks.
Orange Truck is offline   Reply With Quote
