what causes this?
what causes the grear on the distrubuter that meets the cam to strip out?
my engine died on me like 2 weeks ago ans i just pulled the dizzy out and found the gears on my msd probillit dizzy rounded over (that must be the problum duh ![]() ![]()
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door Last edited by special70gmc; 05-18-2005 at 01:32 PM. |
![]() Join Date: Mar 2000
What kind of cam do you have? A roller cam with a steel gear will eat up a dizzy gear. You need a bronze gear with a roller cam. Likewise a bronze gear on a cast cam might not be the ideal combo either.
Saskatoon, Saskatchewan Canada |
Saving 1 truck at a time!
If you destroyed the dizzy gear and all the metal is in the engine you had better tear it down and do an inspection before you risk more damage.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
#4 | |
Here's the special gear for roller cams and the distributor I bought. I'm pretty sure you cam buy aftermarket gears too. Don't know if the price is any better or not. http://www.flatlanderracing.com/distgmbb.html
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
Watch out for your cornhole !
![]() Join Date: Jun 2003
thanks everybody i pulled the cam today to check it out and it seems ok but im going to replace it anyway with a bigger solid lift cam the old was hydrolic flat tappit but i need to figure out what went wrong so it doesnt happen again it looks like the gears werent meshing corectly because all the teeth are worn on the front edge to a point untill the one side of the dizzy teeth snaped and broke off ill post pics tomarrow, but i was thinking that maybe since i put the new intake on 2 months ago that the hight of the ditributer in relation to the cam is wrong? causing the mesh to go wrong maybe? ill have to wip out the ruler and figure out is the dist ride height is correct thanks -kyle
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
Does all that mean that the dist gear material matched the cam after all?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
