Windshield Install- Put Top or Bottom in First if by Myself
Tried to put the windshield in last night following GMCPauls instructions......but it is tough by oneself......since this truck will never be waterproof, I used a ton of petroleum jelly, (not going to use gasket sealer).
Any trick beyond below if i'm doing it by myself? like top or bottom in first? http://67-72chevytrucks.com/vboard/s...d.php3?t=90510 |
Lovin' Life in Miss.!
Can't imagine installing it solo. It REALLY helps to have 2 or 4 more hands pushing/holding. specially if you have the trim! I installed bottom first. I did not use vaseline (that sounds mean) I used silicone spray instead. Only other tip I have is to make sure the pinch seam is even all the way around the frame. I had 2 areas that had a raised seam. Gasket would not completely seal around those areas. Yup had to do it again.
The truck... you hear that? No really, you did hear that?!!! |
yea, i've got the trim too.......so if the that is not totally seated prior to installing windshield, you are not gonna get it to seat later eh?
Trouble w/ silicone is that the rubber just absorbs it, but that might be good if one plans on using sealer. I tried bottom 1st too, guess I just need the 4 hands........ thx |
A classic GM kinda guy
I was always taught that you installed the bottom gasket first, then worked your way up and around.
Hopefully you did wrap a good, heavy, braided thin line around the window at least twice to help you in the installation; that string is used to pull the inner gasket lip through the opening (instead of using screwdrivers). BTW, I have always used at least 3 people when installing windshields in classic GM pickups; that window is heavy, and they can watch to see if the installation is going right.
Old school rap music: a dual exhausted GM 6 with no mufflers. "If you can find a better vehicle, buy it" Lee Iacocca, Chrysler commercials of the '80s. "I did. They are called Classic GM pickups !!!" ![]() ![]() |
i like the wrap 2 times idea! not like you can put it back in if it does not pull first time.........!
December 21, 2012
"!Ama Sua, Ama Kjella, Ama Lllulla!" |
Trim must be practicly perfect. No dents/bends. Instal trim to gasket. Then install gasket. Use 1" 3M masking tape to help hold the trim in place. Tape the trim from one side of the glass over the trim, over the gasket and back to the other side of the glass. Do this spaced every foot or so. Use no tools other than strong fingers and the rope. Once installed remove the tape. You can get it all out. For the rope you can use a surprisingly large diameter. A bit thicker than a lawnmower pull rope. good luck with it.
wow great tips guys! thanks...
The line goes around 1st, then the tape to hold everything together? |
Yes.
