Old 04-11-2002, 09:08 PM   #1
smokeyburnout1967
Question 4 LINK SUSPENSION
Anyone know where to get info on a 4 link or where to purchase one for my sb67
smokeyburnout1967 is offline   Reply With Quote
Old 04-11-2002, 09:23 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
i wouldnt waste the trouble and $$ if you have trailing arm suspension, if not then swap to it, its not hard to do, is all bolt on if you have a coils rear parts chassis
Randy- Lincoln, IL
r68c30@hotmail.com
-71 C-10 350/CH465/3.07 12 bolt 3.07/ trying to assemble! *Life and time permitting* :P
-84 Z28 Camaro 5.0L 700R4, 3.73 rear
-84 Firebird SE 2.8L. 5 speed Borg Warner
-82 Firebird 350/TH350
*parting out 5.0LTPI '81 cutlass supreme brougham, and have lots of '67-87 parts of all kinds to sell or trade*
*Paint is overrated
© RSS Enterprises 2000
[This message has been edited by Fast68Chevy (edited April 12, 2002).]
Fast68Chevy is offline   Reply With Quote
Old 04-11-2002, 10:19 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
The coil set up we have on these is about as perfect as you can get.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-11-2002, 10:31 PM   #4
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
a true 4 link is still better...... id set the engine on 6 stands for better wheight transfer
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 04-11-2002, 10:49 PM   #5
Shane
Shane's Avatar
Post
not trying to start an argument...but if trailing arm suspension, with coil springs, is the best, why do most all the Pro Stock & Pro Mod drag cars/trucks run a 4 link?
I am asking this out of curiousity, not sarcasm.
Keep On Truckin'
Shane
slecroix@bellsouth.net
Athens, Alabama
Shane is offline   Reply With Quote
Old 04-11-2002, 11:48 PM   #6
nate68
Post
i saw in a magazine a suburban with leafs converted to 4-link air ride, i believe it was from air ride technologies
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 04-11-2002, 11:59 PM   #7
imdarren
imdarren's Avatar
Post
Fast, I have a GMC W/ leaf rear. Would like the coil rear. Are you saying the holes and evrything are already there from the factory? Just bolt in the parts? Do the frames come from the factory with holes drilled for both setups? Darren
Darren
Washougal, Washington
darrengale67@hotmail.com
1972 GMC C1500 (Bone Stock)
Saving / Looking for a 72 SWB 4X4 Or 2WD Automatic with little or no rust.
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 04-12-2002, 01:21 AM   #8
sinister72
sinister72's Avatar
Post
if you want coil over shocks, then mount them on the back of your trailing arms. its not hard. and it is cheaper than a 4 link.
72 chevy C-10 swb fleetside,402 BB.700r4,buckets,console.etc.
72 Blazer CST 350,AT, new project
1971 Chevy Nova ,355 SB blow through turbo in works.
sinister72 is offline   Reply With Quote
Old 04-12-2002, 03:15 AM   #9
69 longhorn
Post
If you are racing ,a 4 link is the way to go,as they are more adjustable. Most guys "back half" the truck to set up that way. Another option is a ladder bar,or ladder link,with coil over. These setups dont work too well on the street as far as handling. I have leafs on the longhorn with slapper bars,& have set the eng in on 250/6 stands to move all the weight back that I can. I dont have any wheel hop, but still need a set of sticky tires to get the truck to hookup. I have stretched the rear tubs to fit more rubber,& done many mods on the truck......but have vowed not to cut the frame! If I cant get the thing to hook up, I plan a ladder setup on a custom crossmember(longhorn frame wont except a trail arm setup). Good luck.....69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-12-2002, 09:59 AM   #10
slam33
slam33's Avatar
Post
Trailing arms and coils allow you to keep the payload size, They were designed to work best with these trucks and if it's good enough for NASCAR, it's good enough for a street truck. Do you really think that you can get the same performance out of a small coil over coil spring as you can out of a stock 1/2 ton or 3/4 ton spring. Just box in the trailing arm if you want less flex.
71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
</A>
slam33 is offline   Reply With Quote
Old 04-12-2002, 05:28 PM   #11
SCOTI
SCOTI's Avatar
Post
A true 4-link is easier to adj the pinion angle for different tracks/conditions. If it's mostly a street driven truck the stock style trailing arms are the best way to go vs. a ladder bar set-up as they are basically ladder bars that don't bind like aftermarket units. If you have leafs, your frame will still have the holes in the crossmember for the t-arms so you just need the correct t-arm crossmembers, brackets, braces, shock hardware & stuff & don't use anything less than GRADE 8 hardware when installing.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-17-2002, 06:22 PM   #12
CustomChevy
try here
if you are still interested in the 4link or ladder bars, try these links.
oh, 4links and ladder bars are better than stock suspension anyday, check out the new chevy's lately. subs use 4 links now....
www.competitionengineering.com
www.airride.com
air ride has the triangulated 4 link, great weight savings over stock system, plus eliminates panhard bar. can utilize air bags or coil overs.
good luck!
CustomChevy is offline   Reply With Quote
Old 11-17-2002, 06:45 PM   #13
flyin99
creator of kong
flyin99's Avatar
Here is my 4 bar set up....probably should have stayed with trailing arm set up myself, but I didn't know they were as good as these.....I think if I do another one, it will keep the trailing arms.....
flyin99 is offline   Reply With Quote
Old 11-17-2002, 06:53 PM   #14
CustomChevy
nice setup
stick with what you got, the 4 link is better anyday. good enough for the new suburbans.......
plus you can modify pinion angle and save on sprung weight too.
Old 11-17-2002, 07:20 PM   #15
speeddemon
speeddemon's Avatar
You could also check out www.cachassisworks.com for a 4 link set up.
69-C10 LWB
71- fleetside shortbed
It's a shame stupidity isn't painful
Never play leapfrog with a unicorn
speeddemon is offline   Reply With Quote
Old 11-17-2002, 07:30 PM   #16
flyin99
creator of kong
flyin99's Avatar
Mine was from Art Morrison www.artmorrison.com
Old 11-17-2002, 07:53 PM   #17
bigjimzlll
bigjimzlll's Avatar
if you plan on back halfing it..then I would go with the 4 link..if not..new bushings and the trailing arm is fine.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 11-17-2002, 08:10 PM   #18
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
I'm not saying which is better. I'm not a racer like you guys abviously are. I do find the NASCAR reference hilarious though. I doubt that NASCAR uses the exact geometry or materials as our trucks. It's like saying the all V8's are the same.
That said, I was wondering if a stock trailing arm set up will bolt up to a leaf truck. What about a 4x4 lrear eaf?
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 11-17-2002, 08:22 PM   #19
slam33
slam33's Avatar
Nascar might not have used the SAME geometry or materials but the same trailing arm design was used for a long time, clear up into the 90's
</A>
Old 11-17-2002, 10:32 PM   #20
70 Jimmy
70 Jimmy's Avatar
Not to be a jerk, but internal combustion engines have been used since the early 1900's. Suspension is about geometry. Design is important too but that's just the beginning. Anyway, I'm no expert but I just don't buy the argument. It's still better than my leaf, so I may go with trailing arms if I can't afford the 4 link.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
Old 11-18-2002, 11:43 AM   #21
sniper2321
sniper2321's Avatar
to let you all know the trailing arm in nascar were oem till the new monte cameout i know because i have a use set in my truck from hendricks the cost about 200 for the set know they are longer and are coustom biuld for 3\16 c chanel her are some pic of the new one the they made for me.
sniper2321 is offline   Reply With Quote
