05-19-2005, 10:39 AM | #1 |
Lovin' Life in Miss.!
Is the rubber TIGHT enough?
Plan on taking out my cab tank this weekend. Have new paint and no dough to paint if I install a patch. REALLY don't want to run around in primer. Thinking on just cutting off the filler neck letting the gasket hold it in place. Think it will work? Any ideas?
The truck... you hear that? No really, you did hear that?!!! |
05-19-2005, 11:12 AM | #2 |
More Cowbell....
I don't see why that wouldn't work. I'd cut the neck off and push it in to the cab so the gas cap sits as close to the rubber as possible.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
05-19-2005, 12:13 PM | #3 | |
I did the same thing on the filler neck for my 'extra' tank on my CST. I put a new gasket on it so it looks better but it is just a 4 inch piece of filler neck with a cap on it. If someone tried to siphon from it, they would be sucking a lot of air since it's open to the inside of the bed.
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" Last edited by Lemield; 05-19-2005 at 12:15 PM. |
05-19-2005, 02:58 PM | #4 |
nice grill! u polish it yourself? just did mine, not as easy as one might guess.....
05-19-2005, 05:01 PM | #5 | |
Thanks for the compliment though.
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
05-19-2005, 05:17 PM | #6 |
[QUOTE=chickenwing]Plan on taking out my cab tank this weekend. Have new paint and no dough to paint if I install a patch. REALLY don't want to run around in primer. Thinking on just cutting off the filler neck letting the gasket hold it in place. Think it will work? Any ideas?[/QUOTE
I don't know if you have full service gas or not, but you might want to put something on the inside of the dummy filler neck so someone does not stick the nozzle in & fill up the cab @ $2.50 a gal. |
05-19-2005, 05:18 PM | #7 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
05-19-2005, 06:10 PM | #8 |
December 21, 2012
I got a cut neck off another tank sitting in the rubber piece and it hasnt moved for the 10 plus years its been in there. Just put the locking cap from the tank I took out on it. I cut it so it is sticking out the same length that it was when the tank was in it.
"!Ama Sua, Ama Kjella, Ama Lllulla!" Last edited by Maximum Overdrive; 05-19-2005 at 08:03 PM. |
05-19-2005, 07:47 PM | #9 | |
Got Light Emitting Diode?
[QUOTE=chevyboy55]
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
05-20-2005, 09:07 AM | #10 | |
05-20-2005, 09:19 AM | #11 |
68w/406- your avatar is pretty funny, but what's with the save a kitten stuff? must have something to do with grown up kittens i guess?
05-20-2005, 09:29 AM | #12 | |
05-20-2005, 07:21 PM | #13 | ||
Ot
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler Last edited by 68w/sbc406; 05-20-2005 at 07:22 PM. |
05-20-2005, 07:26 PM | #14 |
I pulled my tank, and set the cap on the rubber gasket. Then I laid a long bolt across the cap on the inside and cable-tied the ears on the cap to the bolt. It's been there for a year with no problems.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
05-20-2005, 07:29 PM | #15 |
Confirmed Truckaholic
I have a friend that did the same thing to his truck. He lent the truck to somebody that put about 5 gallons into the cab.
1968 50th STEP SIDE SHORTY, 350/350, a/c, ps, p,b Daily Driver, 1970 Cst short fleet, all black, 350/350, 1970 2wd Blazer, 2wd, 6 cyl. 3 spd, original, now a 454, 350turbo, 3.73 posi, on the road 1971 2wd fleet shorty, 454, 700r4, 3.73 posi, SOLD to 67OLDSTYLE72 "My rig's a little old but that don't mean she's slow" - SAWYER BROWN's Six Days On The Road SEMPER FI "I use to be a lean mean fighting machine, but now I'm a huffin, puffin, over stuffin love muffin" |
05-20-2005, 10:05 PM | #16 |
I would weld up the end that is inside the truck, therefore no gas inside the cab. I would also weld a flange to that end to allow you to JB weld it (or use the glue that is used to install windshields) to glue it to the inside of the cab. Just my $.02.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 05-20-2005 at 10:06 PM. |
