05-19-2005, 01:53 PM | #1 |
Rack and pinion?
Does anyone make a manual rack setup for our trucks? I would love to do away with my power box, but I wasn't sure if I had to fab a rack in or if there was a kit.
Daily Driver: 1992 Blazer dropped on rallys Project: 87 GMC shortwide, About to get a little boost |
05-19-2005, 02:41 PM | #2 |
get a hot rod magazine they sell them in there
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
05-19-2005, 03:25 PM | #3 |
www.73-87chevytrucks.com
You will have to fab it.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
05-19-2005, 03:52 PM | #4 |
Until Seventy Times Seven
I'm not sure if you are trying to find a kit that uses the original crossmember. I haven't seen one exist. The only kit that I've come across is the Fatman Bolt-in Kit that comes with a R&P crossmember. I think I've seen them listed for $999 in the rags.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
05-19-2005, 07:50 PM | #5 |
is there a manual steering box for the 78-87 trucks? This is a topic I have little knowledge on, so I'm kinda lost.
05-19-2005, 08:25 PM | #6 |
87 short crewcab
manual steering box
Hey 87 shortbed
i think you can use a steering box from a 67-72 chevy truck and just change your pitman arm. but you might dble check. i live in park city,so if you need to locate parts i might be able to help. i go to the salvage yards about every weekend, hope this helps. donnie-87shortcrewcab tbirdman88@msn.com |
05-20-2005, 10:38 AM | #7 | |
Insert Witty Text Here
Slonaker |
05-20-2005, 10:53 AM | #8 |
Yes you can get a manual steering box for these truck. They typically are found on 6cyl base models. I had one on mine '73. BTW, they are a PTA to steer with running anything larger than about 245's.
05-20-2005, 11:54 AM | #9 |
manual was offerend on the straight 6 trucks i got one im buildin and im taken it off
05-20-2005, 12:03 PM | #10 | |
