Old 05-19-2005, 07:45 PM   #1
72gmcshorty
72gmcshorty's Avatar
How does the factory radio mount?
Is there anything that holds up the radio under the dash? I don't see any holes and I don't remember if there was a bracket for the original radio.
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 05-19-2005, 07:47 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
for factory radios there is a bracket that comes off the firewall
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-20-2005, 01:17 AM   #3
warthog52
Yes, as the previous post said. there is a small bracket that attaches to the firewall just beneath the speaker. a support strap (approximately 4-5") attaches to the stud on the back of the radio and the other end attaches to the bracket. This supports the rear part of the radio. Good Luck.
warthog52 is offline   Reply With Quote
Old 05-20-2005, 06:39 AM   #4
JimKshortstep4x4
Talking
There should be a bracket for the speaker mounted to the inside of the firewall just behind the radio. The radio support bracket fastens to the speaker bracket. If you truck never had a radio installed there may not be holes drilled for the speaker bracket but there are two dimples at the right locations.
Here is a picture of the speaker bracket, the support bracket is fastened to the speaker bracket on the right side.
Jim
