Old 05-20-2005, 12:16 PM   #1
ScottH
ScottH's Avatar
Question on 80 something frontend on 77
Thinking of buying a 77 which has an 80 something front end (dual square head lights) and was wondering what I would need to restore this to a 77 front end.
Any info is appreciated.
Thanks.
ScottH is offline   Reply With Quote
Old 05-20-2005, 12:21 PM   #2
tgh117
Crazy
tgh117's Avatar
You are probably going to need fenders, hood, grille, headlights, parking lights, side marker lights for the fenders and possibly a radiator support. That is all I can think of at the moment, I converted my truck from a 77 to an 86 a while back because the body was shot. Good luck.
77 SB Stepside in a bunch of pieces scattered around the garage.
tgh117 is offline   Reply With Quote
Old 05-20-2005, 12:23 PM   #3
Prerunner1982
Prerunner1982's Avatar
fenders, rad support, hood, lights, bezels, grille...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 05-20-2005, 01:22 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
To make it back to a 70's, you need the entire front clip.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-20-2005, 01:24 PM   #5
bodydropped
yea u need from firewall forward i went from a 78-89 frt clip but i live the burb slips better
bodydropped is offline   Reply With Quote
Old 05-20-2005, 03:30 PM   #6
ScottH
ScottH's Avatar
Thanks to all. Still undecided, but will take another look at it tonight.
Old 05-21-2005, 01:52 AM   #7
AspecialZ
Street Rod Restoration
AspecialZ's Avatar
...same thing
Iam building the same thing 81 front end on a 76 good luck
Follow me on Instagram @ hot_rod_shop
AspecialZ is offline   Reply With Quote
Old 05-21-2005, 09:45 AM   #8
1985K10
1985K10's Avatar
Dont forget your wipers! I think 73-80 trucks had shorter wiper posts(so the wipers would fit under the hood) and 81-87 trucks had taller ones(so they would stick up through the cowl)
Anthony
07 Tahoe LT
70 Chevelle 450HP 383-TH400
77 GMC Royal Sierra~Resto in progress~
1985K10 is offline   Reply With Quote
Old 05-21-2005, 03:19 PM   #9
f.monroe
f.monroe's Avatar
Might want to take a look at the cowl area in front of the windshield. Make sure they didnt hack it up too bad if they installed the 81 and up hood hinges . If you are going to want it to look factory when converted back , that might be an issue. You might also check the front of the frame horns where the bumper bolts on .81-87 trucks had the front of the frame horns trimmed and a bumper bracket bolted on . 73-78 trucks are shaped a little different . Frank
f.monroe is offline   Reply With Quote
Old 05-21-2005, 09:38 PM   #10
AspecialZ
AspecialZ's Avatar
f. monroe is very right, they hacked my cowl area all up and they added the longer wiper brackets as above mentioned. Here are the pictures I promissed you, later...
Old 05-21-2005, 11:16 PM   #11
bigarmzz
bigarmzz's Avatar
man i just love a step side bed...
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 05-22-2005, 08:44 PM   #12
AspecialZ
AspecialZ's Avatar
your pic
I found a shot for ya, and I went and took some pics of what they butchered above the firewall and below, simply a sad attempt at a nice resto piece
