Locking up a blazer?
I've been wondering about how to lock up a blazer. Mine has a double wall top and a tailgate like a pickup truck (with the handle outside). How do you lock the truck up? If I close the liftgate and lock it, I can still open the tailgate and crawl in. How is this supposed to work? Is there a difference in tailgates? Is there something wrong/missing from my top? Thanks!
68 C-10 Longbed - LT1/4L60E 71 K5 CST 350/350/205 Never again volunteer yourself! |
You should have a piece that runs across the top of your tailgate that the hatch will sort of rest against when closed. This piece should prevent the tailgate from being opened. I can get a picture when I get home. I have the piece, but I haven't installed it on my tailgate yet.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
I guess I'm missing that piece. Any ide where I can get one?
SKINNY TIRES RULE!
you still shouldn't be able to open the tail gate with the rear hatch down. You're never going to get a first generation Blazer as secure as a new car. The best advice is to not keep anything valuable inside.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Member since 2000
Theres this extra pice that bolted on to the top of the tailgate, it;s just a steel lip. I;m sure that added that for "secruity". Thiefs weren't such a problem back then but then the population wasn't as high either.
I believe those pieces are in the LMC catalog. I think it is called a rear lift-gate stop. It mounts on the top of the tailgate with about 8 screws.
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. |
#7 | |
The hatch gasket rest's on the metal strip completing the 'system' to create a seal. |
Member since 2000
vtblazer that would be a good guess but what about the bottom, when the gate is up there is a gap between the floor and tailgate. I might be wrong but the gate doesn't seal up either on the sides.
#9 | |
Yep, it does. There was (when new/original) a stainless carpet strip that had rubber that sealed to the gate when closed, there were side strips that ran vertically up the sides of the gate with rubber also, all tied into/working with the hatch gasket to make what was considered a 'barrier' from the exhaust. Beleive it or not it even works pretty good when everything is there and doing it's job of sealing. ![]() Last edited by vtblazer; 05-21-2005 at 06:45 AM. |
Member since 2000
oh, never seen such a thing. Never drove britney around with a top much either so............i guess I'm excused.
![]() Thanks for the info. |
<- Determination Pays Off
Vt Blazer
Aaahhhhh... yes... the infamous tailgate trim pieces... You don't happen to have a set do you? I have been looking for them.
![]() ![]() 350/350, PS, PB, Tilt, A/C, 4 wheels Discs, 17" Wheels. Full Leather Interior - SOLD ![]() ![]() |
#12 | |
The LuvShack Garage
Bet I have looked through that catalog a hundred times and never saw that piece until today, I just assumed that I would have to fab one up, Thanks ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 05-21-2005 at 06:57 AM. |
#13 | |
I have two sets but I also have two blazers. ![]() |
#14 | |
![]() No top, no need for the strips. ![]() Here's a couple quick pics of what the stuff looks/fits like. |
#15 |
SKINNY TIRES RULE!
VT-Is the seal on your's one piece? My is getting a little worse for the wear after 33 years and it is one piece. It seems link the only one's I've seen in the catalogs run just along the bottom of the bed and not up the sides. Where did you get your seal?
#16 | |
![]() The two verticle side rubber's are separate from the bed floor strip. |
#17 |
Member since 2000
thanks dude!
I remember the side strips now but mine didn't have rubber in them if I recall. They got to be sitting in a box somewhere since I don't throw anything away. I have the holes in the floor of the bed and never knew what they were for. Last edited by Alexis; 05-21-2005 at 03:37 PM. |
#18 |
![]() Join Date: Dec 2002
Also my blazer when I got 20+ yrs ago had some kind of a seal that ran across the bottom when I got the blazer it was starting to fade then. When your 16yrs old you really don't care but that is designed to keep water out from between the taigate and rear cross seal. Most of the floors that rot out back their are rusting from the top side. Go to LMC catalog pg 15 Item # 25 Tailgate Bumper that is a knock off of the orgininal just saw it will have to get one
#19 | |
I've used that part, it's a glue on application. Works okay as long as your able to get it to stay where it needs to be. ![]() |
#20 |
PROJECT 7DEUCE
I have all the steel strips just need the rubber.... BTW alex you are not my father LOL..... Han is comming up do you have a place to stay yet??
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#21 |
Member since 2000
Going to be staying at the same place we stayed at last time. "Whore street" Hotel dude
