Lower Rad Hose..... Help !
I have a small block with a long water pump in the stock 8 position. 4 Core rad. What hose will fit ?
I don't have any originals around to see if they would possibly work. Any help would be great.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Got Light Emitting Diode?
just try a stock one for a 73up truck. i have a sb400 w/ long pump and a aluminum rad and i got a hose that fit the first time
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
What rad are you using ? Is it a bolt in ? I got a 73 up hose today and it does not fit. The lower neck is curved up unlike the 73 rad.
Any one else have this problem ?
Cantankerous Geezer
Had to trim some off both end, iirc. Here's some pics.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
If your rad has a straight output the "Dayco 70735 ( length code E )" hose will work with a little trimming on both ends. If you don't trim it it won't fit without bending & kinking. Can't remember how much has to be cut off exactly maybe an inch or so off each end. you can always cut more off, but you can't put it back on, so trim & try till it fits. I'm not sure about the rad with the upward angled output. Hope this helps, and I feel your pain brother. I'm still having nightmares about trying to find the right hose.
I got a bench seat baby, you don't have to sit over there. |
Fred,
Is that a stock lower hose ?
![]() Join Date: Jul 2004
Try a NAPA number 7352 for the bottom, it fits curved lower outlet and has hump to clear the high spot on the frame, it will need trimming on one or both ends, and try a NAPA 7368 for the top, it will need triming too.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
If your asking me, I'm talkin about the lower rad hose . ( lower hose, long water pump, and straight out not upward angled rad output aplication) I'm sure that's the correct part #. After the grief I went through finding a hose to fit, I put the sticker off it on the back of a door in my shop. I think it's the hose for the 73 & up trucks, but not posative. Freds pic looks to me like the stock type rad output that angles upward. I'm pretty sure it's a different hose than the one I'm talkin about and won't fit a straight output rad. If I get the time, I'll finally maybe learn how to post pic's and you'll see the differnce. I hope I'm not confusing people. I wasn't exactly sure what rad Mario was talking about so I thought I'd tell what worked for me with my component combination. If it don't help him it might help others.
I got a bench seat baby, you don't have to sit over there. Last edited by purple gas; 05-21-2005 at 12:27 PM. |
i had to trim mine also. it looks like Fred T's
Purple Gas,
I understand what you are saying. When I get to a aluminum rad the 73 up hose which I have already bought will fit. I ordered a stock 72 lower hose and It should work with the long water pump.
Keep On Truckin'
I just bought one today on the way home from the shop for a 1992 Camaro 350 with Tuned Port Injection. I bought a stock 4-core radiator (bottom outlet turns up a bit). It looks very close to the wire hanger I bent to get the general shape of the required hose. I'll see if it fits tomorrow and let you know....
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
Cantankerous Geezer
Stock lower hose off the 73 & later series truck. Trimmed some off both ends.We had a good thread on this a few months ago. Too bad the search is still down.
#13 | |
Keep On Truckin'
Yep, it fit but not real great. Had to cut about 1" off the water pump side and compress the center of the hose to keep it from crimping.
#14 |
Cool,
I ordered a stock one If it does not fit I will try the camaro one.
