Old 05-20-2005, 09:16 PM   #1
Pickemuptruck71
Coast 2 Coast in 61 mins.
Pickemuptruck71's Avatar
Gas Tank Blues
Gents and Ladies; I need some guidance. I have done everything to remove the fuel tank from the 69 donor truck cept shove an M80 in it! I would much appreciate a step by step list of directions on how to accomplish this. Tanks much.....
69 C20
71 C10 40 over 454, AT, 3.08 gears
71 Demon 340, 4spd, 4.56 gears
70 RoadRunner 440 6pack, 4spd, 4.10 gears
99 Dakota R/T 360, AT, 3.91 gears
Pickemuptruck71 is offline   Reply With Quote
Old 05-20-2005, 09:23 PM   #2
71swb4x4
71swb4x4's Avatar
They are pretty easy to remove. Obviouisly you'll want to pull the seat out. Then I removed all of the bolts at the bottom and top of the tank. Then I removed my vent line and the supply line. Then I sprayed the filler with some lube, and popped it out.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-20-2005, 10:20 PM   #3
chevyboy55
chevyboy55's Avatar
pickemuptruck71
B, double E, double R, U, N. Are you a Bob & Tom fan?
chevyboy55 is offline   Reply With Quote
Old 05-20-2005, 10:55 PM   #4
Pickemuptruck71
Mon-Friday on the way to work, Bob and Tom are on my radio.....
69 C20
Old 05-21-2005, 05:29 AM   #5
JimKshortstep4x4
Talking
Is the tank stuck and you can't get it to move or are you having trouble maneuvering it out?
They sit on a tar cardboard like material and sometimes they will stick in place and you have to break them loose. Other than that it should come out easily.
Jim
Old 05-21-2005, 08:26 AM   #6
Pickemuptruck71
The biggest problem is getting the filler neck thru the opening, its like trying to pull a square peg thru a round hole. I'm going to lube the heck outta it and see what happens. Thanks for the help.
69 C20
Old 05-21-2005, 09:16 AM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
You need to get the neck out without the hose on it, iirc.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-21-2005, 09:25 AM   #8
cdowns
cdowns's Avatar
if you're having trouble pulling the neck thru the grommet just take a utility knife and cut the grommet away
Old 05-21-2005, 03:32 PM   #9
Pickemuptruck71
Its out, WD-40 and a quick tug and also the removal of the passenger seat belt.... talk about feeling like a metric nut in a box of sae wrenches..... I can even hear the 15 year old hollering "Dad, don't we have to pull the seat belts" LMBO
Thanks guys for the help
69 C20
