Old 05-20-2005, 09:37 PM   #1
Big Bad 1972 Blazer
Big Bad 1972 Blazer's Avatar
? for those with BB, headers & SM465
Hey guys...
? for everybody running a big block with headers & an SM465. I've got a set of Hedman long headers on my 496 (bolted in almost perfectly). I left the 496 in the stock location (dimpled the firewall for clearance) and was cruising along bolting everything in...until I got to the clutch linkage. The main pipe runs directly in front of the hole for the pivot on the motor side. I don't think that I could bend the header far enough to even get a pivot to screw in...let alone to get enough clearance for motor rock etc. Anyway, I was curious to see what everybody else has done to solve similar problems. I'm probably going to go with a hydraulic clutch set up, but if somebody has a creative idea...I'd love to hear it.
Thanks in advance!
Big Bad 1972 Blazer is offline   Reply With Quote
Old 05-21-2005, 08:03 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
I am running a hydraulic clutch so I don't have a problem but I did notice that my tube was also directly in line with that hole. My headers are the Dynomax headers for a 2wd 67-87 or so truck. You might PM burt4x4. He is using Thorley headers I believe and could look to see if those cause interference. He is also using a hydraulic clutch.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-21-2005, 12:11 PM   #3
bisquik65
bisquik65's Avatar
You simply need 73-85 clutch linkage,z-bar and frame bracket..I have done this...Go under the footnotes in the Big block header # and it will tell you this same thing...And it works fine...
bisquik65 is offline   Reply With Quote
Old 05-21-2005, 10:30 PM   #4
Big Bad 1972 Blazer
bisquik65...
Thanks for the tip...I missed that one in the hedder notes .
Does the pivot for the 73 & up line up with the rearward hole on the block? I've got a z-bar from a 454'd '76. I never enough thought of trying to line it up at that location. That leaves me a frame bracket to score and a couple of holes tor drill in the frame (I assume)...time for another trip to the local salvage yard.....
Old 05-22-2005, 09:13 AM   #5
bisquik65
bisquik65's Avatar
Yes it will use the rear hole in the block now,all you need is a bracket..You will also need the 73-85 clutch rod from the pedal to z-bar. And you need to lower the hole where that rod comes out of the firewall..I forgot about that part.. A Big Block was never put in a 67-72 4x4!!!factory.
Old 05-22-2005, 10:14 PM   #6
Big Bad 1972 Blazer
True about the 67-72's not comming factory with a BB...but boy do they look good with one sitting in the engine bay!!!!
Thanks again for the info. I now should have my '72 driveable by the end of Memorial weekend. Like a kind around x-mas...I can't wait.
Old 05-22-2005, 10:47 PM   #7
bisquik65
bisquik65's Avatar
Glad to help,I was confused when i did this swap and got it right off of the comp,here. Then my other truck blew up,i pulled the motor from my 65 biscayne and put it in the burb,then old bis needed a motor,Why not a 70 LS6 454 4speed,Its one cool car now,The 69 K/20 is parts truck now,with 72 1/2 ton rears bare cab and bed..with 69 K/20 title....coming up for grabs soon.
