Old 05-20-2005, 11:55 PM   #1
phanatic32212
It's Done When It Runs!!
phanatic32212's Avatar
Electric or Mechanical
OK, I'm in the market for a new speedo. I have all Pro-Comp gauges so far. The speedo is all I have left. The gears are off as it is. Should I go ahead and spend the extra $150 for the electrical set-up, or just go with the mechanical and change drive and driven speedo gears? Anyone that has the electrical speedo, what does the sender take to install? Also, what do you have to do to calibrate the electrical speedometer?
Thanks in advance.
Or Give Me DEATH
phanatic32212 is offline   Reply With Quote
Old 05-21-2005, 09:11 AM   #2
Hart_Rod
Hart_Rod's Avatar
I would go with electrical. They are easy to install, only a wire going through the firewall and not a cable. Any time you change gears you can reprogram it to the correct speed very easily. The sender just screws into the tranny where the speedometer cable screws in. It has a couple of wires that you run to the back of speedometer. It's pretty simple and the flexibility of reprogramming it it an awesome feature.
Rob
Hart_Rod is offline   Reply With Quote
