05-21-2005, 10:57 AM | #1 |
looking for part number....
Would anyone know the part number for the kilometre per hour speedo? I'm sure there has to be some of those laying around somewhere...
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
05-21-2005, 11:00 AM | #2 |
Never heard of that before. The best I have found is a dealer sticker that goes on the plastic lense.
I am omost positive they do not exist.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
05-21-2005, 11:14 AM | #3 |
good luck, # 6492869 get 2 if you can and let me know.
Rod
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
05-21-2005, 12:10 PM | #4 |
Speedo
Only shows one speedo in 72 parts book. GM must of had some kind of export parts book separate from the regular parts book.
Rick / Ca. |
05-21-2005, 12:11 PM | #5 |
Don't bother I tried a few months back, and the dealer got back to me after a week of waiting for word from GM in the states and there are none available. I tried for both the speedo and the lense.
05-21-2005, 05:06 PM | #6 |
6492868 is the mph speedohead
05-21-2005, 05:36 PM | #7 |
Why would the speedo head be different? wouldn't the lense numbering just be changed?
Not trying to be an ass, I just am reallly curious about this. The next one I build I want to go with the KM speedo. P.S. I borrowed the pic... Last edited by screamin_c102; 05-21-2005 at 05:38 PM. |
05-21-2005, 05:42 PM | #8 |
Check out the increment lines on the KPH and compare to the MPH speedo
05-21-2005, 05:43 PM | #9 |
Screamin, go look at your MPH speedo, its not the same as the KPH in your picture. The MPH speedo has 10 large marks as opposed to the KPH which has 8 marks.
If IIRC 100mph should be close to 160kph so you should be able to repaint a MPH speedo to mimic the KPH speedo and switch out the MPH lense for the KPH lense.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
05-21-2005, 05:44 PM | #10 |
I am too slow
I guess the odometer would still be messed up though, so it's not as simple as repainting
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. Last edited by 71swb4x4; 05-21-2005 at 05:45 PM. |
05-21-2005, 05:49 PM | #11 |
You could get away with a MPH head but the lines won't match the numbers, not sure how notciable that would be. In theory you could mess with the tranny speedo gears to get it to read correctly. If anyone would like a KPH lense contact 68 50th, he was looking to get some decals made up to mimic the look.
05-21-2005, 05:55 PM | #12 |
I think the speedo itself would read correctly with the correct lense and new painted marks on the face (100mph is 160kph), but the odometer would not. If you messed with the tranny gears you could get the odometer to read in kilometers but then the speedo would be off.
05-21-2005, 06:03 PM | #13 |
Yah I guess the speedo would be already correct as it is for speed if you were to just change the lense.
05-21-2005, 06:25 PM | #14 |
I feel pretty dumb right about now.
