Bite me, import boy
heater hose routing
After 15 years of being apart, I'm having a memory lapse on how the heater hose routing is supposed to be on my 71.
I have a fitting in the intake, the water pump and a fitting in the radiator. The one picture that I can find has the upper heater fitting going to the radiator and the other going to a tee that fed an inline coolant heater but I can't tell where it connects at the engine. My 69 396 has a conventional setup with one hose going to the intake and one going to the water pump. I can't find anything in the assem. book showing the extra radiator fitting. Any pictures or recommendations would be appreciated.
Jason '71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project "Facts are meaningless, You can use facts to prove anything that's even remotely true." |
member #16
![]() Join Date: Dec 1999
The 5/8" hose should go from the intake man to the lower heater inlet, the 3/4" outlet should go to either the water pump or rad, depending on year model. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Bite me, import boy
Thanks for the reply.
