05-21-2005, 06:49 PM | #1 |
Front End Options
I'm considering two options for the front end of my '69 GMC:
Option 1: Replace the front crossmenber with a crossmember from an '84 that I scored at the wrecker. He cut the frame just behind the front cab mounts and sold it to me with all the steering and brake parts attached. Easy to swap in. Advantage: Easy swap, 5 bolt, disc brakes, power steering, cheap. Option 2: Keep the stock set-up, but buy new front spindles and a new disc brake set-up (or find parts at the wrecker and rebuild them). Advantage: A bit less work and mostly stock. Disadvantage: COST. What do you think? What else should I be considering?
Present: 2015 Tacoma. Yeah, not a GM, but I love it. 1969 GMC 32,000 - fix, drive, relax, fix... 2019 BMW R1250 GSA - Yahoooooooo 1979 Honda GL 1000 - retro touring at its best. Past: '05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner. '94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm. '79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350. '76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod. '68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect. '59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said. |
05-21-2005, 07:23 PM | #2 |
I have the same question, only a different front end donner. I have a 73 front end and all the parts still on the truck. As soon as I have some extra time, plan to go though as many post as I can find on the subject. I already know my 73 will bolt right on with only 2 holes to drill. What I do not know is if I can bolt the 73 parts onto to the 69 cradle, would be a lot easier if the 69 cradle would accept the remaing parts from the 73. If I learn anything new I will post it here.
05-21-2005, 08:18 PM | #3 | |
Got Light Emitting Diode?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
05-21-2005, 11:03 PM | #4 |
Check out my parts:
http://67-72chevytrucks.com/vboard/s....php3?t=156778 Everything you need. Rob robhartley@aol.com
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-21-2005, 11:47 PM | #5 | |
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!! |
05-22-2005, 01:00 AM | #6 | |
05-22-2005, 11:32 AM | #7 | |
05-25-2005, 02:24 PM | #8 |
Any opinions about the quality of the 67-72 control arms/bushings vs. the 73+ versions? The 73+ seems to be a more robust piece.
