Old 05-21-2005, 10:32 PM   #1
Striker169
Car O'Holic
Striker169's Avatar
Hotwireing
Ok so I couldnt get the old key switch out of the old cab but I need to move the truck how can I start the truck with just the black plug that goes into the back of the key switch? What wires do what?
Striker169 is offline   Reply With Quote
Old 05-21-2005, 11:37 PM   #2
modifiedGMC
The easiest way is run a wire from the positive post of the battery to the positive terminal on the coil (or the batt terminal of HEI). Cross out the switch terminal (the small one closest to the engine) and the battery terminal (the big one) on starter. The engine will run but to cut it off you have to disconnect the wire you hook up from the positive post on battery.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!!
modifiedGMC is offline   Reply With Quote
Old 05-21-2005, 11:50 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
One note, doing it liek that will not let the battery charge.
Old 05-21-2005, 11:53 PM   #4
modifiedGMC
It will work just to move it though. no accesories will work that way. I wouldn't drive it that way.
Old 05-22-2005, 12:23 AM   #5
Longhorn Man
exactly.
Old 05-22-2005, 01:18 AM   #6
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
if you have a spare ignition cnat you unplug the one and plug in the other? of course thats if you have another
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-22-2005, 11:48 AM   #7
71swb4x4
71swb4x4's Avatar
You can just unplug the plug from the switch. Then use one wire to jump the power to the run position. and a second to tap the power to the start. They are labeled on the plug but I dont remember which is which. I did this about a month ago to start my parts Blazer and drive it around the yard. Worked very well.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-22-2005, 03:08 PM   #8
Striker169
Car O'Holic
Striker169's Avatar
Its labled? Oh I didnt see anything on mine but Ill look again.
Old 05-22-2005, 07:05 PM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
wire labels
The red one is hot and the pink one feeds the gages and the ignition and the purple one is the starter solenoid wire. I find that cotter keys work well for jumping but don't let them touch a ground and be sure you have the vehicle in park or neutral. Go from red to pink then red to purple until it starts then just red to pink.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-22-2005, 09:32 PM   #10
71swb4x4
71swb4x4's Avatar
Unfortunately, you may want to use this thread as a warning to come up with some sort of kill switch, so someone doesn't do this to your vehicle!!
