Old 05-22-2005, 12:48 AM   #1
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Oil will not read on my dipstick unless my truck has been running for awile???
Okay in my '79 pickup, 350 SB, lots of miles probably, looks like an older engine.
Oil will not even read on the dipstick in my engine unless the truck has been running for a minute or two and then it reads really high. Was a tad bit low about a week ago,filled it up. Drove it for like 3-40 miles maybe went to check it yesterday, would not read on the stick. Added a little bit hoping that it would read and it never did. Oil does not leak anywhere and truck does not smoke either.
Anybody got any ideas or suggestions, I have not seen this before.
-Thanx
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 05-22-2005, 03:50 AM   #2
BodyShopDropOut12
9 months
BodyShopDropOut12's Avatar
You can't get a level check on the dipstick unless the engine/oil has been warmed up to idle? I'm not a mechanic by any means, but I'd say thats normal.
"You'ins gonna go?"
BodyShopDropOut12 is offline   Reply With Quote
Old 05-22-2005, 04:17 AM   #3
1FaastC10
1FaastC10's Avatar
no that's not normal. drain it, change the filter, and put 5 quarts in it. if it has a stock pan on it, that should put it right in the ballpark.
you arent trying to check it while its running are you?
1FaastC10 is offline   Reply With Quote
Old 05-22-2005, 10:32 AM   #4
screwballl
Tonawanda 454
screwballl's Avatar
damn 1faast beat me to it... i had same problem on my 76 for the first week i had it... once i gave it the oil change it was fine...
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 05-22-2005, 12:59 PM   #5
cliffsta
Stepsides RULE
cliffsta's Avatar
Checking fluids (as i know how it supposed to be done)
Oil: Engine cold and not running
ATF: Engine and tranny at operating temp in Neutral or Park
P/S: Either way as the capstick has both marks
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 05-22-2005, 04:19 PM   #6
Hoods69BadBowTie
Chevys Kick A$$
Thanx for the suggestions!!
No, I no the engine is supposed to be off and cold. I just changed the oil like a month ago and it was very dirty and black but no metal or anything else came out with it. What I was trying to say is that the oil wont read on the dipstick unless it has been running for a little while. I know that is not accurate though. I did drain the oil but not change the filter this time because I just did it. Filled it up with almost 5 qts. and it still won't read on the dipstick. I did not think it would matter if I put in a new filter since I did it just like a month ago??
-Later
-LATER
Old 05-22-2005, 05:47 PM   #7
f.monroe
f.monroe's Avatar
Almost sounds like the drain holes in the lifter valley and also the heads are clogged . I would pull the valve covers and check the cylinder heads to make sure the drain holes are open . The engine is probably sludged up . You said it doesnt smoke . Have you let it sit and idle for about 10 minutes then revved it up a couple of times ? If the oil is sitting in the top of the engine (valve cover area) it will smoke at this point . I bought an old truck once and this was the problem . I removed the intake , valve covers , and oil pan . I filled the engine with as muck Degreaser a I could , washed it out completely with a water hose and sprayer , and reassembled it . Believe it or not it really ran good after that . If yours is clogged you could probably leave the intake on it . I ran mine for a day then changed the oil again and all moisture was gone . Just a thought .Frank
f.monroe is offline   Reply With Quote
Old 05-22-2005, 05:47 PM   #8
slingin mud
Mark
slingin mud's Avatar
I had about the same prob when I dropped the oil pan there was a piece of garbage stuce up in the oil pump since then np
Look at every day as a holiday, some just better than others.Build what you got be happy with what you have This truck is for sale
slingin mud is offline   Reply With Quote
Old 05-22-2005, 06:41 PM   #9
Hoods69BadBowTie
Chevys Kick A$$
Thanx, I was going to tear it apart today and get started looking for simple stuff like that. But it has been drizzling alot.\
-Later
-LATER
Old 05-23-2005, 11:14 AM   #10
GMCLS1
1987 GMC Sierra Classic
GMCLS1's Avatar
You may have the wrong dip stick installed.
Gary L Hilton jr
GMCLS1 is offline   Reply With Quote
Old 05-23-2005, 01:33 PM   #11
crawdad
crawdad's Avatar
That's what I was thinking...wrong dipstick.
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
