Old 05-22-2005, 09:51 AM   #1
armyavncowgirl
C10 Junkie
armyavncowgirl's Avatar
adding power steering.......
to a truck that didn't come with it.
I got the gear box, pulley and pump and the bracket necessary to install it. My question is, with a 327 V8 motor what size belt should I get or should I just do the string method and measure it that way? Any ideas and if anyone had ISSUES when installing pwer steering in their truck, let me know.
09 Chevrolet HHR --- Cruck --- cross between a Car and a Truck
Former rides:
1967 C10 LWB
1972 C10 LWB
1969 C10 LWB (parts truck)
armyavncowgirl is offline   Reply With Quote
Old 05-22-2005, 11:00 AM   #2
JimKshortstep4x4
Talking
Installing the power steering is pretty straight forward. If you have a truck setup with short waterpump, you should be able to just buy the belt for the year truck.
If you are not sure of the year, pick a year and try it. The parts store where I shop has no problem with exchanges so if I miss on the first try then they will exchange the belt for me adding or subtracting the difference. Hopefully you have a parts store that will understand. I think that wrong belts are fairly common so it should not be too big of an issue.
Jim
Old 05-22-2005, 11:14 AM   #3
armyavncowgirl
C10 Junkie
cool, thanks
Former rides:
1967 C10 LWB
1972 C10 LWB
Old 05-22-2005, 11:27 AM   #4
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i asume that this is on your 67. one issue that you could run into it if the frame has the relief in it for the power steering box or not. also you will have to notch that bumper bracket
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-22-2005, 11:44 AM   #5
armyavncowgirl
C10 Junkie
i'll take a gander at that as well
Former rides:
1967 C10 LWB
1972 C10 LWB
Old 05-22-2005, 12:10 PM   #6
68w/sbc406
68w/sbc406's Avatar
i think all 67s didnt have it, and half of the 68 didnt have it either.now that i think of it there might be a intermediate shaft difference too that can be changed
Old 05-22-2005, 02:44 PM   #7
boogie67
boogie67's Avatar
power steering
I just did that on my 67.Like they say I had to heat up my frame and put the demple in it and notch the rad suport bracket.Had no problem with the steering shaft.Everything worked out great.
77 swb starting all over again.
boogie67 is offline   Reply With Quote
