Old 06-15-2002, 03:08 PM   #1
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
Adjusting doors
Any tips for this i couldnt see what tools would really fit in there to get at it with the door on and the outer fender on too. Any suggestions please?
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 06-15-2002, 07:34 PM   #2
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
I have found that ratchet gear wrenches work really well for adjusting the doors. Sears sells them.
Ben
67Fleetsidedream is offline   Reply With Quote
Old 06-15-2002, 09:08 PM   #3
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
That's what I was going to say, I just couldn't put a name to them.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 06-15-2002, 09:16 PM   #4
speeddemon
speeddemon's Avatar
There is also a special Boxed in wrench that is shaped like a "S".
69-C10 LWB
71- fleetside shortbed
It's a shame stupidity isn't painful
Never play leapfrog with a unicorn
speeddemon is offline   Reply With Quote
Old 06-17-2002, 01:33 PM   #5
Erl
Erl's Avatar
Sears sells a tool called an Obstruction Wrench that is "C" shaped 9/16 and 5/8 box end. I have used this and it works pretty well. Cost about $16.
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 06-17-2002, 01:52 PM   #6
Woody
Well NO Doubt about it, it is a Bi#ch to do. But I used a box/open wrench. The S- shaped wrench should work good. I found that if you leave the bolts just loose enough to hit the door with your hand, you can get it where it belongs then tighten it down.
Hope this helps! Good Luck!
Woody is offline   Reply With Quote
Old 06-17-2002, 02:21 PM   #7
Big69C20 Toy
Livin' it up.
Thanks fellas, i'm gonna try it as soon as i get it back from the paint shop...
-Greg;
