I was thinking about trying to make my own bed floor out of some aluminum as it is pretty beaten up and then have it rino lined.
I really like the look of the wood floors but I use the bed of my truck to haul engine parts,feed,lawnmowers,etc so Im going to stay away from the wood beds. If you have a pic please post it.
Life is good with a 6-71 supercharged 355 in a 72 camaro ![]() |
This is what I made for mine. This is certainly not done yet, though.
69 Chevy ProStreet, Low and wild. 78 Corvette rturnpaugh@compcams.com |
Hey that kinda reminds me of the back of my 72 camaro
![]() Ahhhhhh I love tubs. But I was wondering how well a flat floor made of aluminum would hold up when being used alot for hauling heavy parts etc. I know the framing under it would help but I dont want a warped rino lined aluminum bed floor ![]()
Seņor Member
I made a floor from steel diamondplate. I'd say it will be in the truck long after I'm dead and buried... no matter how much abuse it gets. For a stepside, it's an easy task to have a steel supplier cut it to size and you just toss it in there. For the fleetside there's a little more work, but nothing that should take too much effort.
Kenneth
My bed floor is aluminum diamond plate. Here is a picture.
1969 Custom 30 wrecker
My stepside has 1/8" thick stainless steel for a floor. (in it when I bought it) I plan on putting in a rubber mat over it as it gets slick as ice when wet. I never have to worry about it rusting anyway.
If you want durability, stainless is really tough! This bed floor will be here longer than all of us! LOL
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
#7 | |
Re: Anyone made their own bed floor???
previous owner of my pickup welded a steel sheet over the top of the wooden bed. very durable and strong, but a pain in the arse for me to grind off and remove.
1967 Chevy swb stepside-work in progress 2005 GTO-daily driver 2001 F250-weekend car crusher 1956 Chevy Pickup-sold |
![]() Join Date: Mar 2005
i put a piece of 3/16" flat plate in my stepside bed and used 3/4" sq. tube on top of the cross sills to support it.
Mine will be bagged with a raised flat bed floor. I am wanting to do 1 solid flat sheet. I will have a grid type pattern under the stainless floor with angle around all 4 corners. I will also be doing a cali combo and have the fleet meet up to it. I will also have a rubber strip down for squeak and stuff with stainless bolts/screws holding it down with lock nuts tack welded underneath. I want the sheet removable to access anything under it.
#11 | |
Eat, Sleep, Drive a Chevy
I remember a member here that made his bed using some newer type composite material like they build decks with. I will see if I can find it
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
#13 |
If you build a decent frame under it you should be fine. These are some pics of the frame I did in my Suburban. You can see more pictures in my build thread.
My 72 Suburban Build - http://67-72chevytrucks.com/vboard/s...d.php?t=454019 79 Volvo Turbo LS Build - http://67-72chevytrucks.com/vboard/s...d.php?t=594252 Buggy Bed for son - http://67-72chevytrucks.com/vboard/s...d.php?t=657350 |
#14 |
Looks good Bruin. That's what I was thinking about doing on mine. I do want to make it removable though. So instead of welding it to the grid I will bolt it down with SS fasteners.
