Im doing a TPI swap into my 68 and I was wondering how you guys ran a fuel return line to the tank on your swap.
Also how is it vented etc?
Life is good with a 6-71 supercharged 355 in a 72 camaro ![]() |
Got big-block?
![]() Join Date: Jul 2000
Pick up a copy of Street Rodder magazine. Somebody in that mag - I can't remember who off hand - sells an aluminum fitting that goes into your g-tanks filler neck hose. You cut the hose, and use this fitting to splice the two hose ends together. The fitting has a fuel line nipple already welded on. All you have to do is attach your return line to it and you're ready to run.
It's made to make efi installs easier. A lot better than tapping a return line into your tank. Might work for your app. SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
its all about the +6 inches
I think Jegs might have that.
Got big-block?
You're right longhorn. I just checked my Jegs catalog and there it is. Made by Moroso. Jegs part # 710-65385. Must be a 2" fuel filler tube. Comes with clamps and everything. $38.99.
SC
Thanks for the info
![]() I will be sure to get it and I will let you know if it works.
