What master cylinder for manual brakes?
I am thinking along the lines of converting my 87 over to manual brakes, instead of power. I am still running drums in the back, so what master cylinder should I go with?
My reasoning for this swap is pretty simple really. I want to simplify more of the firewall, and getting rid of the booster will help this alot. Also, I would like to do away with the stock proportioning valve so that I can run an aftermarket adjustable proportioning valve and incorporate my Line Lock system in a more simple, and cleaner fashion.
Daily Driver: 1992 Blazer dropped on rallys ![]() Project: 87 GMC shortwide, About to get a little boost ![]() |
nobody?
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Mastercylinder should be the same, you just need the shorter rod for it.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
You need a Manual Brake master cly form a 87 and older The power and manual have diffiernt size cly. They are avaible from your local parts store. You might need another rod thats shorter.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Awsome, that was the answer I was waiting for!
