05-23-2005, 09:27 AM | #1 |
II Timothy 4:2
Gas cap question
Just put a cab tank from a 67 into my 72 c-20. I have a question about the gas cap. I am using an old one my dad had laying around, and every time I turn right with a full tank, a small fortune in gas pours down the side of the truck. Will a new cap do this? The truck didn't have a cab tank in it when I got it, so I really have no experience with them.
Question two, since it's a 67 tank, the only holes in it are for the filler and the sender. Do I need to get a vented cap? I would think so, but thought I would ask and make sure.
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus" MY TRUE PRIDE AND JOY "Dangit, Bobby, people will see that oil stain and think I'm a drunk." |
05-23-2005, 10:21 AM | #2 |
67-72 Addict!
Your "old" cap probably has a dry rotted shrunken gasket on it.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
05-23-2005, 12:53 PM | #3 |
I agree, you probably have a dry rotted gasket. In the past I have cut out gaskets from cork or other comparable gasket material and just replaced them myself. Sometimes you may need to stack up 2. Easy cheap fix that worked pretty well for me. Good luck trying to save the precious liquid.
67 short wide 355ci 3 on tree 69 short wide 250ci 3 on tree 68 long wide 283 3 on tree 72 2wd Blazer project 454 5 speed |
05-23-2005, 02:00 PM | #4 | |
II Timothy 4:2
